Question about Whirlpool Duet GHW9150P Front Load Washer
Error codes I am getting & F-28 error & an F-11 error on my whirl duet sport. I tried calling the 1-800 #, but it is more frutrating then the washer. The manual only talks about F-20 & F-21 errors. Does anyone no where I can find a place where these codes exist. Thanks
  • 1 more comment
  • kaang69 Dec 17, 2008
    It helped with F-11, but what about f-28 error??
    Thanks
    PLEASE just tell me what f-28 means. The links are all taking me back to the same site.
    Thanks
    thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If after all the figuring out what the codes mean and trying any and all remedies, pls consider checking out the electronic control board:
  • replace the board assembly; or
  • check for cold solder, cracked board, open trace, burned/corroded connector pins.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 17, 2008
  • 679 Answers
On the right side of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear, I saw the same problem posted in another post I found on Google, try it , as it really can't hurt, Gym
  • George Bill
    George Bill Dec 17, 2008
    Google it like this,
    F-28 error & an F-11 in whirlpool Ghw9150p,
    you will see all related errors and solutions, Peace, Gym
    Genius:
  • 1,199 Answers
Http://www.applianceaid.com/duet_washer.html have make and model ready and they will give you the code meanings!
    Sergeant:
    Novelist:
  • 327 Answers
  • classyexpert Dec 17, 2008
    F28 error is..
    The communication between the Central Control Unit (CCU) and
    the Motor Control Unit (MCU) cannot be sent correctly.
    Possible Causes/Procedure
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the MCU, the motor, and
    Central Control Unit (CCU).
    – Check connections of the CCU board within the housing.
    – Make sure all grounding switches are engaged.
    3. Check the drive system for any worn or failed components.
    4. Plug in washer or reconnect power.
    5. Verify CCU operation by running a Diagnostic Test or any
    cycle.
    6. Check the MCU by looking for operations of the drive motor.
    7. Check the drive motor for powered rotations.
    8. Check that the serial harness at the MCU is not mounted
    upside down. The wires should be to the left when facing
    the MCU connectors
    If it is new call for service...
    Top Expert:
  • Whirlpool Master
  • 77,499 Answers
This is the condition fo the F28 error code
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
This is what you need to check and or repair
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
5. Verify CCU operation by running a Diagnostic Test or any cycle.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
WHIRLPOOL DUET WASHER MODEL #WFW9600TW01 F-35 & F-28 ERROR
The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
Oct 28, 2014 | Washing Machines
How do I clear error code F-28 on my Whirlpool Duet Sport electric dryer?
The tech sheet is located under the kick /service panel in a jacket. Suggetions and codes are in it. Duet sport service manual
Sep 30, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet sport model WFW8300SW Have error F-22 and F-28, how to solve it? Thks
Relates to an electrical/electronic problem
Try the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport washer is giving a F-28 error message. What is wrong?
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet sport washing machine has F-28 error
i have the same problem... and i got it fixed 3 times.. the frist time.. there was stuff stuck in the pump... but every time i go look in the pump.. theres nuthing and i still get f-23... good luck..
Jan 21, 2010 | Whirlpool AWM9000 Front Load Washer
Duet Sport Washer fault code F-28
f-28 code is a serial communication error between the central control unit-ccu- and the motor control unit-mcu-. depending on the age under one year the unit should be under warranty, if so call a service man that care of the problem in warranty. if the unit is over one old you can remove the top and check all connections between the ccu and mcu.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
