Question about Acer Aspire 3000 Notebook
No kb or mouse in winxp
Laptop has a cmos password enabled. We type just fine, when it boots to windows xp no keyboard and no mouse
    Brigadier General:
  • 5,158 Answers
Go here and download the drivers that you need for xp ....
http://global.acer.com/support/index.htm
put them on a usb flash drive and transfer them to the laptop... use a usb mouse to access give you a mouse on the acer and install the drivers ... reboot and all should work... there is one issue... is that is a very new computer that had vista pre-installed ??
sometimes they are not reverse compatable for operating systems... i've tried putting xp on my compaq desktop computer and there are no xp drivers for some of the devices.
Robert
Posted on Dec 17, 2008
If is nor fn button on my computr what can I do for unlock my mouse an keybord
I assume you have a laptop since KB and MOUSE are usually auto enabled by the BIOS on PCs at boot time and by OS after boot. You should be able to re-enable EXTERNAL KB & M in the BIOS (press DEL or F1 usually on power up) look for "enable legacy keyboard & mouse" in the menu system.
Feb 15, 2016 | Computers & Internet
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
I forgot my password how can i log on to windows
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope it helps
Jul 03, 2012 | HP OmniBook XE3 Notebook
Forgot password
or if using XP
hope it helps
May 29, 2012 | HP Mini 110-1037NR Netbook
Acer aspire one kav60 restore asking for a password.
or if using XP
if still no luck
click start type cmd press enter
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten hope it helps
Apr 27, 2012 | Acer Aspire Computers & Internet
ACER ASPIRE ONE KAV60 AOD250-1198 RESTORE AND NO PASSWORD
or if using XP
if still no luck
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Apr 27, 2012 | Acer Aspire One PC Notebook
How CAN I GET TO SETUP TO CHANGE BOOT MEDIA ?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account. Hope this helps you
Feb 26, 2012 | Computers & Internet
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
hope this helps you
Sep 10, 2011 | Computers & Internet
Remove..administrator
HI!, I had met the headache things that I had forgotten Windows login password. The login screen rejected my passwords. I was frustrated because there was very important data on my disk and I couldn't reinstall the OS. ............. However, I fortunately got to know the Windows Password Recovery Tools below .
1. Windows Password Recovery Tool 3.0( http://www.windowspasswordsrecovery.com )
2. Windows Password Key 8.0( http://www.lostwindowspassword.com )
3. Windows Password Recovery 6.0( http://www.recoverlostpassword.com/products/windowspasswordrecoery.html )
4. Any Windows Password Reset 7 ( http://www.windowspasswordreset.net )
5. Windows 7 Password ( http://www.windows7password.net )
6. windows password cracker ( http://www.windowspasswordcracker.com )
I compare these tools and try the first one, it help me to recover my forgotten windows xp password in only five minutes.
May 04, 2010 | Apple MacBook PC Notebook
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
