Question about Whirlpool GEW9878LW Electric Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
I have Whirlpool GEW9878LW Electric Dryer. My Dryer will only work if I hold start button, when I release start button the dryer stops. I made sure the timer is on, dryer door is closed. Usually I set the time for the dryer and push start and it starts working. Please help. Thanks in advance.
  • 8 more comments
  • Anra Rakra Mar 28, 2007
    This is Anra again. I went to the suggested link and could not find "even heat board. Could you please give more explanation or the exact name of the item I need to find.
  • gscout Nov 04, 2007
    I too have the same problem. The start button is pushed but won't stay on. Door is closed, lint tray is clean, drum will turn but won't stay running. Joni :o)
  • Anonymous Sep 29, 2008
    Whirlpool LE4634EQ2 My dryer is doing the same it only stays on if I hold the start button. What do I need to replace.
  • muddywatersb Jan 12, 2009
  • Anonymous Mar 12, 2014
    Dryer timer works but dryer won't start?
  • Anonymous Mar 13, 2014
    Lg Dryer control panel not responding- its stuck and no button will work. The dryer is on the only way to stop it is open the door. If I close door it just runs and runs
  • Anonymous Mar 16, 2014
    will run while i hold start button but stops when I release it
  • Anonymous Mar 26, 2014
    Hi I have a calypso dryer an just recent it stopped working after changing loads the problem is that when I push a button then push the start button it just beeps an won't start up u have any idea what's wrong
  • Anonymous Mar 31, 2014
    Dryer does not start because there is electrical problem even though it is plugged in the electrical socket
    President:
  • 878 Answers
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
  • Ron Marek
    Ron Marek Mar 28, 2007
    Anra, your part number is 3976623, it will take care of your problem...Catriver
  • cemer Mar 07, 2011
    I am helping a girlfriend of mine with this exact problem. I came here because I've used this site as well as ordered parts through the repair clinic - GREAT help/resource!!!
    Her's is a Whirlpool Gold Model dryer (I believe she gave me the washer model number though GSX9885J) - but it's the mate to dryer to the set. She states that the when she holds the button in it runs but as soon as she lets go it stops. She seems to think it is just the button/switch/timer mechanism only. I believe you; that it's the "even heat board" and I saw the post back with the part number. I am going to ask her to verify the model number - but I guess my question is; is there any way that this can be only a timer/switch issue - like the button won't click in? I need to see it in person too - which I will. But, I'd hate to steer her in a wrong direction (us women need to keep impressing our husbands with our fix-it sensibilities!). Carolyn
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Kenmore 64902 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Whirlpool GEW9878LW Electric Dryer Logo
1,235 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
