Question about Grohe Home
Grohe shower assembly leaking
I have a Grohe shower assembly with a pressure balance valve and a floor spout.  When I turn the water on, it comes out of the shower head as well as the floor spout, even though the diverter is set to the floor spout only.  Also there appears to be a small amount of water leaking behind the shower wall as the drywall outside of the shower is wet (from the inside) where it meets the floor pan.
  • 2 more comments
  • Anonymous Mar 14, 2014
    Shower will not turn off
  • Anonymous Mar 29, 2014
    cannot unscrew shower head support
    cannot unscrew
  • Anonymous Mar 31, 2014
    Had a power failure now can't get the electrics wireless shower to work comes up 12 service , press again says priming but nothing coming out!!??
    Scholar:
  • 44 Answers
Hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
My graff shower assembly is dripping from the tub spout when the water is off. What are the most common reasons for this? I recently had my water line to my house repaired and wonder if some dirt may have...
maby there is dirt traped behind the showers lock rubber. bt it sounds to me like it is the lock rubber(close) rubber that has parished. replasing the rubber should fix it
Jun 15, 2010 | Graff G-7065-LM15S-P ; G 7065 LM15S P...
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Diverter valve does not work correctly.
    the connections are reversed,just change them over and this will fix the problem.
    Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
    Dripping shower head
    If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
    Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
    Water kitchen sink
    I would check the strainers on the intake and the faucet spout. It is possible that sediment has built up and now is impacting thermostatic flow from the faucet... if one side is clogged its hard for the faucet to balance... try the stainer on the spout and any other strainers that may be on the supply hoses, valves, intake, etc...
    Nov 23, 2008 | Moen 3175 Legend One Handle Shower Faucet...
    Home Logo
    1,250 people viewed this question
    Top Grohe Home Experts
    Mike
    Oloyede Monsuru
    Are you a Grohe Home Expert? Answer questions, earn points and help others
