Question about Black & Decker B2300 Bread Machine
B2300 breadmaker Brand new. Does not change slections or beep or light up.The only thing that beeps isthe on button
I had the same problem and what you need to do is hold the start button down for 3 seconds and that will clear the default setting (1 3:30). Then select the settings you need starting with the program setting for your recipe (i.e. #4 for sandwich bread). Bear in mind that you may not be able to select your crust light/dark option for some recipes, but will be able to select the loaf size. I assume this is because the recipe program (i.e. #4 for sandwich loaf) is already prescribed in the setting. When you have all of your selections then press your start button, but don't hold it down for longer than a second because it will clear everything and you will have to start again from step 1. Good luck!
Posted on Feb 15, 2009
Mine has the same problem !!
Posted on Jan 06, 2009
How to reset bread machine
push the start/stop button until it beep (takes a few seconds before you her the beep) then choose the program you want. If that doesn't work unplug your machine and start over.
Apr 19, 2013 | Black & Decker B2300 Bread Machine
I have a brand new APC 1000xl I just plugged into the wall and it beeps every second with all the lights changing with each beep.
You can push and hold the on button to start a self test. Or you can turn off the UPS. Unplug it from the wall. disconnect the batteries and push the on button to reset the logic. if that wont work return it.
Oct 18, 2011 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 19, 2011 | Black & Decker B2300 Bread Machine
How do I start the bread machine, I've followed all instructions but the machine just beeps and beeps for a long time until we unplug it
Use and Care Book for the Black& Decker All-In-One Horizontal Deluxe Automatic Breadmaker is here:
http://useandcaremanuals.com/pdf/B2300UC.pdf
It sounds like a programming error. Be sure you all following the setting and programming instructions completely and that the breadpan is propely seated in the unit.
Mar 13, 2011 | Black & Decker B2300 Bread Machine
My machine does not beep to add ingredients in the lo carb setting yet the recipe suggested in the maker's book says it should.
If your machine is under warranty you should return it per the instructions. If you want to keep the machine and just adjust to the fact that you don't have the beep you can still add ingredients at the right time. Most manuals show the actual time into the program that the add in beep occurs if you find the page that show the length of all the programs. It will look like a big chart.
Invariably the add-in will occur about halfway during the 2nd knead. Even if you don't hear the beep you can set a kitchen timer to alert you during the 2nd knead. Call me if you need further instruction.
Dec 24, 2010 | Black & Decker B2300 Bread Machine
Can only use programmes which allow changing the crust setting to 'dark' other programmes half bake the bread.
This is a tough one. One thing you might try until you can replace your machine is to look in your manual and look at the page that shows the cycles of the program you chose. I wonder if you could shut the machine down after the last rise cycle next time,,,,,the,,,,. Push the Stop button until it beeps.... then unplug your machine and reprogram your breadmaker on the "Bake" program and set the time by pushing the timer advance button in 10 minute increments to the equivalent of the last bake cycle of your original program for light crust bread? That just might work!
Oct 22, 2010 | Panasonic Kitchen Appliances - Others
Brand
black and decker is the best brand you can buy it is durable and last longer good luck to you my friend.
Feb 20, 2009 | Black & Decker B2300 Bread Machine
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Black & Decker B2300 Bread Machine Logo
252 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
