Question about Dayton Electric Heater
Need wiring info on DAYTON 3E342A. All info needed .
The wire comming out of the heater are black (3) Green(1). Trying to put this unit in my garage. Inside , the wires go to a block with marks A1,AB,and ONE with no mark. Is this a 3phase unit ? Can I use it for a garage? Any advise helpful. Thank You.
If you will google the make and model number you should find a pdf owners/ service manual
Posted on Dec 18, 2008
Need to know what size wire to use to wire up a DAYTON GARAGE HEATER model 3UG73 10/2 or 10/3NM to a 30AMPS circuit?
You want to use the 10/3 wire... the red and black are the hot, the white goes to the nuetral and the green/bare wire to the ground.
Use a 30 amp 2 pole breaker..
Heatman101
Feb 24, 2010 | Heating & Cooling
Dayton heater model 3e342a it throws breaker as it starts to heatup what is wrong?
It appears you eirther have to small of wire installed.
I am assuming this is electric heat. The breaker could not be big enough.
The nameplate stamped on the unit should tell you
how manyamps it draws and the max size breaker
should be used.
Jan 31, 2010 | Heating & Cooling
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Dayton electric garage heater
need to check you fan wires, some have differant colors on the moter for the differant speeds, you may need to change the fan speed by unplugging one of the wires and replacing it with another. hopefully you still have the manuel , check with it first!!!
Nov 09, 2008 | Dayton Electric Heater
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Lot of the wires came off the on the back of the Heater
We have a Dayton Unit Heater in the garage, gas. the wiring is a mess do you have schematics?
Sep 23, 2008 | Dayton (3E386) Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dayton Electric Heater Logo
293 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
