Question about Yamaha DVX-S120 System
Yamaha DVX-S120 On Screen Menu - Phillips brand
Hi Does anybody have any suggestions as to why my DVX-S120 should suddenly change its on screen menu and splash screen from Yamaha to a Phillips on screen menu and splash screen which are totally different to Yamaha's. And it will now only play DVD's in B&W Thank You Dieseldog
  • Nigel Atterton Jun 21, 2007
    Fix from Yamaha for this problem :-
    DVR-S120 Version Matrix Setting
    1. Remove disc , turn off the system.
    2. Push ?STANDBY/ON? key with ?A/B/C/D/E? key pushed simultaneously.
    3. Within 4 secs push the ?MEMORY? key.-----It displays [ver. Disp].
    4. Push ?Shift? key + ?2? key simultaneously on the remote controller.
    the FL-Display shows ?Wait 20 sec? and video output goes off after awhile.
    5. DVD module will be rebooted and video output comes again.
    the FL-Display shows [OK S120G(2)] etc.
    6. Open the tray and push the ?MENU? key on the remote controller.
    Confirm the part of the screen shown below.
    *Confirm the ?DVD FW version? and ?version matrix?.
    *Especially check all [8] digit of ?version matrix?(Region) , for version matrix differs depending on each destination.
    REGION 22200606
    DESTINATION UK--Zone-2
My Dvx subwoofer quit working? It makes the noise as if it turns on when pushin the power button but there is no bass whatsoever.... Ive made sure all the settings are correct and cant figure it out. Ive had it into best buy because I had the same b/w problems but everything has been good up until this. Please somebody help me
Posted on Sep 12, 2010
The same happened to me! DVD's play fine but on screen menu just changed and Video Output option is gone! Also de Philips logo on screen which I suspect is placed there by my TV (which is a Philips one) and as it does no longer receive the background screen from the DVX it just puts its own. Is your TV Philips like mine?
Posted on Jun 20, 2007
Reset factory settings
Hi,you need to go into the setup menu,check for vidoe settings and change video output to pal,thanks
Nov 03, 2013 | Yamaha Televison & Video
How to connect Yamaha DVX-S120 to a Pioneer PDP-504HD
You need an audio out jack or jacks from your tv....to input on sound system. .
May 14, 2017 | Yamaha DVX-S120 System
Sanyo CP29YS2B - Picture has zoomed in/enlarged
My Sanyo CP29YS2B - all of a sudden picture has changed - it now looks like it is in a zoom mode - large parts of the eterior of pictures and menu settings do not appear on screen. Using menu does not offer any solutions
Jul 13, 2010 | Sanyo 42 in. LCD TV
Phillips Plasma Picture Way Off Center & A Static Line Appears
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Jun 03, 2017 | Televison & Video
Distorted picture, after changing "TV TYPE"
well here goes
its going to take a little finness but i think i can help
i got the owners manual infront of me
find dvd/cd press it. then setup button on remote go to the osd menu you probably wont see it cause its a little fuzzy
but were going to try and walk threw blind, video menu is the first one on menu so its going to be one down
that tv type
one over to right arrow keys
one down to ntsf setting then hit ok (enter)
this way is a blind walk threw but will get it done if have patiences
the other way you mentioned is that your missing preferneces
will see and check
the other is [preferences page]- [default]- [reset] Press enter (ok) to reset the paremeters to initial factory settings
this can be found on page 38 en of the manual i will also post the link so you know what i am looking at hope these too things work i know you cant see your screen but a blind walk threw is better than not having the preferences not being there for you
http://www.generalmanual.com/pdf/yamaha/DVX-C310_manual.pdf
May 06, 2008 | Yamaha DVX-C310SL System
Video/dvd/cd play but no sound from speakers
Try changing "audio" setup in your TV to "variable" instead of "fixed", if you have that option on your TV set up... I have a Sony HD widescreen, and that worked for me...
Feb 16, 2008 | Audio Players & Recorders
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
DVR-S120 doesn't play any cd's
I have come across one DVR-S120 that has a shorted spindle motor. This is the motor that spins the disk. Therefor the unit will not play a cd or dvd. Yamaha sale's the complete dvd Assy. for $300 witch is absurd.
Jan 13, 2008 | Yamaha DVR-S120 DVD Player
Sound Interference coming throught the Amplifier
On many occasions high pitch interference is a result of bad wiring and grounding problems. Check to make sure that you followed the manufacturer's instructions concerning grounding and installation of the amp, and if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local Yamaha dealer. If you're out of warranty I suggest locating a professional repair person.
Jan 17, 2006 | Yamaha DVX-S120 System
Yamaha DVX-S120 System Logo
305 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
