Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
The Brushes don't turn on my Hoover Steam Vac DuetV
I've cleaned the wire mesh filter under the unit and I've reseated the the tanks, etc. and can't find anything thing else that might be causing it. I've flipped the switch for the brushes back and forth to on without anything changing either.
Can I fix this myself?
  • ARI50 Dec 18, 2008
    Thanks Maanita,
    Not the answer I was hoping for but I'll take it into the shop.
    Sergeant:
    Novelist:
  • 327 Answers
CHECK INTERNALLY SOMETHING MIGHT BE BLOCKING THE BRUSHES TO MOVE.CLEAN THAT MANUALLY AND TRY.
Posted on Dec 17, 2008
    Genius:
  • 1,142 Answers
Well it needs a tech to get the issue resolved,
How to clean brushes on hoover steam vac?
Hi, it's Allie from Crucial Vacuum!
Cleaning the brushes on your unit is a very easy and important tank to do! Your deep cleaner is equipped with removable brushes for easy cleaning. First, make sure to remove the clean water tank and recovery tank to prevent possible leaking. Tilt your unit backwards making sure the handle is in the upright position. Grab the brushes and pull firmly. You may clean the brushes with running water. Do not forget to check the brushes for any tangled hair strands or debris that can prevent the brushes from spinning properly.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Aug 21, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Cleaning the brushes on your unit is crucial in maintaining your Hoover performing at it's best and it is very easy to do. First, make sure your unit is off and unplugged, and make sure to remove the clean and dirty water tanks to avoid any possible leaking.
With the handle in the upright position, tilt the unit back and rest it on the floor. Grad the brush assembly and pull firmly until you remove them from the unit. Clean the brushes with running water until the water runs clear and the brushes are clean.
You can purchase direct your replacement items from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
My hoover steam vac
OKay! I've figured it out! After making sure I had the cleaning solution container connected properly, the "lint filter" thingy clear, the attachment plug thingy unplugged, the filter in it's proper position, (about a cm down from the seal), and the seal on the filter was all good, etc etc etc, the brushes in properly...I was about to drive over this steam cleaner with my car!
After taking a break and going back to it, I discovered that I didn't have the lid to my dirty water tank (or air tank, as I was starting to call it) properly closed. There are two lips that you have to make sure the lid "hinges" from, and THEN snap the lid shut. This made a seal that allowed this steam cleaner to **** up all kinds of gooey gunk from my carpets! The brushes work, the suction works, it's a FABULOUS machine! It doesn't get any louder when it's sucking up water, either.
All this AND I had the instructions! Go figure!
Jul 12, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
52 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
