Question about Brother Personal FAX-190
Brother personal fax190 paper jam - Brother Personal FAX-190
  • Brother Master
  • 13,433 Answers
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Printer paper jam
Go To Below official Brother Printer Page For Your problem, How do clear paper jams Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Mar 24, 2014 | Brother DCP 130C All-In-One InkJet Printer
How to remove a paper jam brother printer
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Get more information and help for Brother Carriage Jam .
Nov 29, 2010 | Brother DCP-9040CN Laser Printer
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
How to clean the paper feed for brother mfc 7820 multiple jams
It's difficult to said just by typing, you better get your printer services person to clean it for you.
Mar 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Personal FAX-190 Logo
209 people viewed this question
James Cagle
James Cagle
Jim Keysor
