Question about Garden
Engine will not run when chock is not on
How do I find where to adjust the carburetor on my Poulan Model PP258TP pole tree saw? Is it inside the housing?
  • Anonymous Mar 19, 2014
    WHEN POINTING UP
    when pointing up
  • 211 Answers
Hi
Try this link to find out where the carb adjusment screws are http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=401c0624-691d-43f6-9249-845e18527269&cat=3&TF=epcFrame&assem=452&highlightNode=No&selAssem=4447&mdDescrip=PP258TP Pole Pruner.
best regards savumihai71
Posted on Dec 19, 2008
Poulan pole saw pp338pt--chain at the end of the pole does not turn when engine running
Make sure the drive shaft inside the tube is making contact and is turning. Sometimes these can pull away from the clutch or can become damaged. This is where you need to start looking.
May 28, 2017 | Poulan Garden
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Engine dies when throttle engaged, assume carb needs adjusted, how to do that?
I'm not familiar with your brand of machine, BUT...
This symptom usually is not an indicator for a need for a carb "adjustment," but instead, it indicates a need to clean-out "gum" and "varnish" in the TINY passages [called "galleries"] inside your carb!!!!!
The gum and varnish problem is caused by leaving old, stale fuel in the carb for long periods of time.
May 22, 2014 | Poulan Pro PP258TP 12ft Gas Tree Pruner...
Poulan Pro PP258TP fuel mixture
The manual calls for 40:1 but with the new "FD" rated oils it can operate on 50:1 ratio. I recommend using the pre-packed fuels. They have the "FD" rated oil and 93 -95 octane non-ethanol fuel.
May 17, 2014 | Poulan Pro 8" 25cc Gas Pole Saw PP258TP
Can get it to run but snap throttle it boggs down and some times dies tryed changeing fuel cap with a bran new one tryed ajusting mix screws new plug gets bettter but problem still there
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Check for spark at the plug--it should be blue and snappy (gapped 0.020"). If it looks weak, try a fresh plug first--if still weak, remove the left side engine cover to expose the flywheel and ignition module. Turn the flywheel magnets under the ignition module, insert a thin business card into the pole gaps, loosen the module screws to allow the module poles to contact the magnets. Tighten the screws, and rotate the flywheel somewhat to remove the business card. Rotate the flywheel one complete turn to make sure the pole gap does not close up further. Reassemble and test for spark again. This process seems to have fixed a lot of Poulan saw problems. Finally, turn both carburetor jet screws CW to stops (lightly), then turn each 1-1/2 turns CCW. Start the engine and allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-stroking. Correct adjustment is when the engine still 4-strokes when running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly smoothly, but will still allow the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Nov 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
All Models:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
Feb 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Jun 16, 2009 | Poulan Garden
Garden Logo
302 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
