Question about JVC AL A158BK Turntable
JVC Turntable model AL A1 BKX , need to know how to adjust speed
Put on new turntable belt but sound from speakers shows the speed is too slow. Any corrections that can be made? Ca I get a layout of the proper belt setup?
  • 3 Answers
I have just fixed this problem on my Aiwa PX3800 with improvisation.
The platter was rotating too slowly, I didn't know how much too slow only that the records sounded wrong.
I imagined the belt, motor and platter as a bicycle gear and so simply increased the gear... I achieved this by winding a thin strip of a electrical insulation tape around the motor head to increase it's radius (like changing up to a larger front cog on a bicycle gear).
I could then time the rotations and remove a layer or two of the tape accordingly until I have achieved a perfect 45rpm. 33 is still way out but I only listen to 45s!
Be sure to trim excess tape from the motor head with a craft knife/scalpel or it'll stick to the platter.
Poor man fix up.
Posted on Dec 23, 2011
After trying all the adjustments that I could by moving the drive motor around in the available slots I've concluded that my trouble now must be with the drive motor itself. I have clocked the RPM speed in both the 33 and 45 settings and they register well below their requirements. Looks like I will have to check out the motor or just bite the bullet and buy a new turntable as this one is quite old..
Thanks.
Posted on Dec 18, 2008
The turntable slows down every two or three revolutions as shown by the strobe light and the sound of the LP
If this is a belt driven model it could be the sign that the belt is worn, causing it to slip.
Apr 14, 2016 | Audio Players & Recorders
My JVC turntable has no plug, just a 10-13v lead
Probably as long it produces DC. However you will have to adjust the speed. As the unit was set for a certain voltage which wouldn't change. It will either go fast or slow depending on what the original voltage was. The speed adjuster will either be two presets one for each speed that could be located under the turntable base (covered by a sticker) or on the power board of the deck. Or they might be on the motor itself.
Apr 26, 2014 | JVC AL A158BK Turntable
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Speed switch doesn't work
hi, maybe you hve to replace the tack switch of your turntable even thougr you switch but the contactss maybe not in the connection,,
Apr 09, 2009 | JVC AL A158BK Turntable
How do you reinstall drive belt for JVC AL A155 model turntable?
http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Feb 10, 2009 | JVC AL A158BK Turntable
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 07, 2008 | Audio Players & Recorders
JVC AL A158BK Turntable Logo
1,486 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
