Question about Weather King 10PJA2501AH Air Conditioner
None cooling 10PJA2501 Weatherking
I had a house built in 2003 and every year since the summer of 2003 we have had to get Freon put into the system and also have been told that the Compressor is bad in the first year. I have yet to get a new Compressor or Central unit. The units are all placed up and down my street by the same builder and we all have had the same problems. Good luck with your systems working!
  • Anonymous Apr 27, 2009
    10PJB24A01 heat pump installed 10-31-05. It has been repaired 5 times and still isn't cooling. I'm on my 2nd replacement compressor. Filter is plugged now so it's 85 degrees in here (Sunday, can't get new filter until tomorrow). Monday will make repair #6 and I am not confident that it will run without further repairs. I think Weatherking is junk. Read the comments on furnacecompare.com. I am going to contact Rheem just ASAP for some satisfaction. Maybe a representative will come from the company to look at this unit.
    President:
  • 1,462 Answers
Comment only : the only reason for re-gassing any refrigeration is that there is a leak. re-gassing is ofted dignosed by those who don't know what they are doing.
Posted on Mar 30, 2007
2003 Chevy Venture Problems
You have excessive pressure built up in the cooling system. You may have air in the system as well. I would suggest purging the cooling system and making sure your thermostat is working properly.
Jun 18, 2013 | Cars & Trucks
Adding freon to my home air unit my air is 4 yrs old am tired paying this company every summer to add freon and it keeps flooding my house never gets cooler than 80 they come out at least three times a...
Why would you be paying for refrigerant on a 4 year old system when most systems have a 5 year warranty on sealed systems.
Sounds like who ever it is servicing is ripping you off.
Jul 24, 2010 | Heating & Cooling
Not cooling house. Its never worked.
Check and see if the inside and outside coils are cleaned , if they are , have someone come out and check the freon in the unit it can leak out over a period of time.
Jul 20, 2009 | Weather King 10PJA2501AH Air Conditioner
Central AC unit not cooling
If you have access to your piping system you may use a soap bubbles to test the pipe connection. the leak gas will blow the bubbles if there is leaking. But if your system is out off freon gas, you can not use this method. just try it check the connection first put the bubbles around it.
Jun 04, 2009 | Heating & Cooling
Compressor valve failure
That is not correct. The system is not mis-matched. They just put a heavy condensor outside to get more air volume for your house. The failure of the valve is not to common of a failure but can and will fail. The problem with Palm Springs is the weather you get there, From very hot to very windy with sand storms to freezing rain and sometimes snow depending on where you are. What is the tech wanting to cahrge to replace the valve? Also this is something that should have been looked at closey and examined before the home was bought and that should have been known by the realator
May 22, 2009 | Heating & Cooling
A/C Gone Warm
U have a leak in the system, be it a very slow one. Have the systek leak tested with a black light, it comes from the factory with dye that glows under a black light leak detector.
Apr 21, 2009 | 2003 Ford Explorer
No cooling although A/C runs normal.
Sound like possibly low on freon. Can't say for sure without getting my hands on it. Only reason to be low on freon is a leak somewhere in the system. A/C's don't "use" freon; the system should be completely sealed. I recomend turning the system off until you can have a qualified professional check out the system as it is very ******* the system to run it if it is truly low on freon.
Jun 25, 2008 | Heating & Cooling
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Weather King 10PJA2501AH Air Conditioner Logo
507 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
acrman404a
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
