Lexmark T 630 - does not respond
I have a Lexmark T 630 with duplex. A few hours ago everything worked fine. But now, it does not respond (no LED light, no output on the printer screen, no noise at all). It is connected to electricity. The power socket works fine with other devices.
Do you know what the problem could be?
What can I do to make it work again?
Thanks a lot,
Borkert
  • Anonymous Dec 29, 2008
SOURCE: Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
I could see no piece of loose rubber on the feeder wheels that guide the paper through for copying. The clicking is coming directly from that area. So for now....I just open the top of my printer where I scan pictures....and then copy from there.
Posted on Apr 07, 2008
  • 35 Answers
SOURCE: lexmark printer power problem
NO IT HAS A POWER CORD THAT PLUGS IN BACK
Posted on Jun 09, 2008
  • 137 Answers
SOURCE: 5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jun 21, 2008
Jay_Sav
  • 93 Answers
SOURCE: My HP Photosmart C4480 will not turn
If you are confident with electronics, remove the rear casing near the power socket, and check the power supply board for a fuse. Using an exact match, replace the fuse and replace the cover. Try powering up. If it fails, you have a blown power supply :(
Posted on Mar 05, 2009
beeveez
  • 167 Answers
SOURCE: can't get computer and printer to communicate
Make sure the wireless LAN of your computer is set to AdHoc mode if the Printer is set to that function.
Posted on Mar 11, 2009
Lexmark c734dn door closed but printer eads door is still open
Power off the printer. Unplug it, actually a few hours. So if this is at work, unplug it before you leave and plug it back just after you arrive.
Feb 05, 2014 | Lexmark C734dtn - Printer - color - duplex...
T632 duplex jams
Please ensure the power connector wires for the fuser are routed properly so as not to rub on the aluminum bar that is used during the duplex function.
Apr 03, 2013 | Lexmark T632 Laser Printer
IBM L190 LCD - the LED beside the power button corner cycles green for 1 second, off for 1 second as soon as it is plugged in. The unit won't power up, the LED just cycles green/off whenever it is plugged...
It's clear the problem is the display, but you can still try these 1. unplug and replug while the both is on 2. turn on, off couple of times 3. keep the LCD on for about one hour these are anyway temporary fixes :(
Jan 30, 2011 | IBM ThinkVision L190 19" LCD Monitor
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
Lexmark X5470 powers on and off constantly
I encountered the exact same problem with my Lexmark X5470. After a power failure on Aug 20, the printer would reboot itself every few seconds. I unplugged the power cord and/or adapter for a few minutes and after replugging, it worked fine. However, the problem returns after I power off the printer and then turn it back on, in which case I unplug again for a few minutes. Hope this helps.
Aug 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
The duplex option is not working anymore on my Lexmark C760
Check in printer menus if duplex is recognized by the printer, is not try to see if connector between printer and duplex is not damage. I had this same problem and had the replace the connector. damaged it connecting the printer to it.
Mar 27, 2009 | Lexmark C760dn Laser Printer
Despite being plugged in and the green LED light on, no display on printer
I have the same model (about a year old) but there are no lights visible on the back of my printer (neither red or green). Have you contacted the Lexmark tech advice website about this problem? They may take a few days to respond but there are numerous possibilities in trying to locate the fault (probably in the power circuitry) and it might have to take it to a repair shop to get it tested (if it is not under warranty).
Sep 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
No power
Hi Bret! Since this is a brand new printer, I would advise calling Lexmark. I'm afraid that you may void your warranty if you do much more at this point except for going back through the steps to make sure the duplexer was installed correctly.
1. Power off the printer and unplug the power cord from the wall outlet
2. Push the release button, and gently lower the front door.
3. Release the green tabs and lift up the image transfer belt.
4. Remove the cover over the duplex connector.
5, Remove the duplex option from the packaging. Carefully install the option into the printer, under the image transfer unit. NOTE: Make sure to line up the arrows on the duplex option with the arrows on the printer. Make sure the duplex option locks into position.
6. Lower the image transfer belt back into position. Make sure the belt locks into position.
7. Close the front cover.
8. Plug the printer back in, then power the printer on.
9. Try printing a few pages to confirm that the duplex option is securely installed. Then select the duplex option in the software and print a few double-sided pages to confirm that the duplex option is working.
The following link will take you to the instructions for enabling the duplex option in the software.
If the above does't work, I would strongly suggest contacting Lexmark for further help.
May 13, 2008 | Lexmark T630 Laser Printer
54 people viewed this question
k24674
jasbo
jasbo
