Question about GE Profile PSS26NGS Side by Side Refrigerator
Freezer on the ge refrig will not freeze - GE Profile PSS26NGS Side by Side Refrigerator
    Scholar:
  • 33 Answers
Dear Brendadurran,
please rate this solution if it meets ur need,else choose fixya.
please perform the following checks,
  • Check the temperature setting
  • Clean the condensor coils
  • Unplug the freezer, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • hope this would help,please rate this solution if it meets ur needs,else choose fixya.Thank you.
    Posted on Dec 17, 2008
    Sea Breeze
    • 4655 Answers
    SOURCE: Frost inside and ice on floor of freezer
    The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
    Posted on May 19, 2009
    • 19 Answers
    SOURCE: GE refrig side by side 7-8 yrs old will not freeze frig not cold
    Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
    Posted on Jun 15, 2009
    Sea Breeze
    • 4655 Answers
    SOURCE: We have a GE Profile refrig, circa 1995. The ice
    If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
    Posted on Aug 20, 2009
    heatman101
    • 43501 Answers
    SOURCE: GE refrig not cooling. model PFS22SISS
    As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
    Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
    http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
    http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
    http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
    heatman101
    Posted on Apr 21, 2010
    woodchuck789
    • 4070 Answers
    SOURCE: GE Profile Bottom Freezer Refrigerator
    The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
    If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
    If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
    With an ohm meter it should show continuity when cold and none when warm.
    You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
    The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
    If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
    If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
    Posted on May 05, 2011
    MY GE MONO SIDE BY SIDE REFRIG,MDL ZISS480DRSS IS FREEZING THE REFRIG SECTION.THE TEMP READ SAYS IT IS NEARLY 80!I THINK IT MAY BE REACTING TO THE TEMPERATURE DISPLAY AND TRYS TO COOL IT DOWN.HELP!
    Here are possible parts that could cause the problem
    GE Refrigerator Freezing Food but the most common is the diffuser/damper that got stuck open and cold air from freezer continously coming in to the fresh food side.
    Nov 22, 2017 | GE Refrigerators
    Freezer is fine, but refrigerator is not cooling at all.
    check the damper vent door between the refrige and freezer behind a plastic grille and make sure theres cold air coming in from the freezer,sometimes they freeze shut from condensation and can't open to cool the refrige
    Jan 01, 2011 | GE Profile PFSF5NJW
    Items in refrig are freezing when they're not supposed to.
    thermostat has failed i'd say..its not turning off at the requested temp.
    Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
    My refrig is freezing items on the refrig side.
    likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
    Feb 19, 2010 | Refrigerators
    Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
    Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
    Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
    Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
    Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
    See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
    Jul 12, 2009 | Refrigerators
    May 18, 2009 | GE Refrigerators
    GE PFS22SISBSS Refrig compatment freezing
    There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
    Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
    Freezing in refrig and freezer.
    call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
    Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE Profile PSS26NGS Side by Side Refrigerator Logo
    121 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
