Question about HP OfficeJet 7410 All-In-One InkJet Printer
Grabs two sheets when sending a fax
When I send a fax, it almost always grabs two sheets of paper insted of only one at a time. I have been standing and feeding each sheet one at a time. Also, is there a manual or guide showing how to completely clean the machine? I bought it used and has a lot of dust. Mahalo,
  • Tom Carson Mar 27, 2007
    It is a HP Officejet 7410 All-in-One.
    Mahalo,
    Thanks however, it looks like a sheet of technical specifications. Is there a manual showing how to do a through cleaning?
    Mahalo,
    Scholar:
  • 121 Answers
Sounds like it just needs to be cleaned. If you can give me the make and model of the fax, I'm sure that I can find the manuals for you.
Posted on Mar 27, 2007
  • Joshua Hori
    Joshua Hori Mar 27, 2007
    Here's the manual in pdf format:
    http://h71016.www7.hp.com/html/pdfs/Offi...
  • Joshua Hori
    Joshua Hori Apr 02, 2007
    I apologize about not getting to this sooner, here's a better manual for you:
    http://h10025.www1.hp.com/ewfrf/wc/manua...
    Once again in pdf format, but I checked this one and it had a cleaning section within it. There is one thing that I would like to add...There is a lubricant that you can get from a bicycle shop that works GREAT for lubricating the gears, although I forget the name for it now...Just remember, WD40 is NOT a lubricant!!!
When we send fax, the rubber roller on top which grabs the sheet does not have enough pressure to lead the sheet in the machine. So the fax cannot go through and be sent. Do people still provide service...
Hello
The paper pickup roller in the Feeder is bad and needs replacement. But still if you want to use it for some time then you can clean the roller with some cleaning liquid like a glass cleaner, even indl. alcohol also. But remember that the liquid should not be applied directly to the roller. Always use a clean cloth for this. And do not take much quantity so it should drip inside. Try to clean well by rotating the roller slowly.
Take care.
Jul 25, 2011 | HP LaserJet 3030 All-In-One Printer
Paper feed on send
Have you checked that you have no paper jams?
Nov 09, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother intelli fax 2800
It could be that your sending fax is sending paper not facing the scanner. In that case tell them to turn the paper over to send. Other than that, it could be that the telephone lines are so dirty that the fax protocl fails at the check frame signal. You will have to adjust the equalisation and line attenuation. Don't count on the telephone company to help you, they always want you to do everything 1st before they will admit to any fault on their part.
May 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
SF-3100 Paper feed problem
You need to clean the friction pad. If you open the part where you put your sheets in to send faxes you will see a white pad behind the cover. You need to clean it, if it still feeds more than one page the pad is probably worn.
Jan 09, 2008 | Samsung SF-3100 Plain Paper Inkjet Fax
Material I'm trying to send doesn't 'feed'
does it try to grab the paper?
do you hear anything happening before the beep?
The machine recognises that there is paper, then you should hear the communication, once it has the correct signal telling it the line is available for transmission it will feed the paper.
look at the tires and see if they turn to feed the paper, is there something in the way, do the tires turn,???
if yes clean with alcohol and try again, if the tires are too smooth then they need to be changed.
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
78 people viewed this question
Clive
Clive
