Question about Kenmore 16322
Loss of pressure on Kenmore 16322
I can't get the temperature of my Kenmore model 16322 above 200 degrees. I've cleaned the tubes, used a new tank, let the regulator and hose empty out between tanks and cranked the valve on the tank to full open. The first burner lights fine. The second burner lights but pops, sputters and hisses the flame is weak. The third burner lights fine but reduces the pressure on the first 2. The 4th burner won't light. Then the 3rd goes out by itself. Pressure reduces with each burner I turn on. Flames linger in the box areas between burners. The grill is 2 years old and this problem has come and gone. Now its always stuck this way. Seems like not enough pressure to work properly. Dave from Phoenix, AZ
  • 1 more comment
  • dvdheckler Dec 19, 2008
    Thanks for the solution. I have tried a few times and still have the same problem, though.
  • dvdheckler Dec 22, 2008
    I found my original instructions and the one thing they mentioned was to turn the gas on SLOWLY. That was the one thing I didn't do. Apparently the regulator on the hose will slow the gas flow if it feels there is too much blasting through. So less is more.
    It works fine now.
    Thanks for all who have helped!
    Time to get those steaks on.
  • spiazza Apr 25, 2009
    I have the same problem and figured it was the opd on the tank. However, it has happend with several different propane tanks. I can usually get it to work by turning on the tank valve very slowly. Unfortunately this does not always work. I an considering replacing the regulator that came with the bbq. It is interesting that the problem is common on this model. Maybe the regulators are faulty?
  • Kenmore Master
  • 8,220 Answers
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Posted on Dec 17, 2008
  • Dan Webster
    Dan Webster Dec 20, 2008
    This is a statement propane cylinder users sometimes make
    following the exchange or re-filling of their bottle. The bottle feels heavier
    and obviously is filled with propane but opening the valve produces no escaping
    gas. OPD valves are designed so that propane will not flow from the service
    valve unless it is hooked up to a hose end connection. This is the way the OPD
    cylinder valve was designed. Unattached propane cylinders equipped with OPD
    valves will not allow gas to flow when the service valve (handwheel) is opened.
    The same is true of forklift cylinder
    OPD Valve Design
    The design of the OPD valve is such that turning the cylinder service valve
    handwheel will not produce any effect if the cylinder is not hooked up to an
    appliance. In other words, a connection must be made between the appliance hose
    end and the cylinders service valve. The inside of the OPD valve is engineered
    to only allow propane in or out if the internal valve is actuated by being
    depressed. This OPD valve feature adds additional safety in case the handwheel
    is turned, opening the valve. For this reason, OPD equipped cylinders will not
    allow gas out of the cylinder when opened. The same is true for industrial
    forklift cylinders. Click the photo of the OPD valve (left) to see a larger and
    more detailed picture of the of the internal flow valve.
    See additional OPD Valve Information
    Hose End Connection
    The hose end connection on either a fill hose or appliance supply line is
    designed to work only with OPD equipped cylinders. For the OPD valve to operate
    with the handwheel open, the hose end connection must be securely attached. The
    picture to the left shows a hose end connection. Notice the elevated brass
    fitting is surrounded by acme threads. When attached to a cylinder valve and
    tightened, the brass fitting will push the internal valve open and allow gas to
    flow out of the cylinder to the appliance, if the handwheel is in the open
    position. This fitting must be in place for gas to flow out of the cylinder.
    Otherwise, turning the handwheel will not produce the intended result.
What is the operating pressure of freon in a 2006 town and country?
Typical R134 pressures are 25-35 p.s.i. low side and 200-300 p.s.i. high side, all measurements taken with ambient temperature above 85 degrees farenheit. At idle, with fan high and system in recirculate mode, you should be able to attain an output temperature at the vents of 40 degrees below ambient.
May 09, 2015 | 2006 Chrysler Town & Country
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Oct 09, 2014 | Water Heaters
Kenmore plt083-2 won't heat above 200 degrees
Please check that model number again. The one you posted comes up as a refrigerator. Look inside the oven door or the lower drawer.
Feb 03, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
91 Ford Ranger 4X4, 4.0,AT. When the ambient temperature is is below 75 degrees it runs good. When the outside ambient temperature is above 75 degrees it begins to misfire at freeway speeds. If you...
Hello, There should be a sensor in the air snorkel and if it is sprayed with a choke or brake cleaner it is probably unreliable. This part can be cleaned with Electronics spray. The sensor measures the incoming Air temperature and makes engine adjustments based on temperature.
You can get a free scan at Autozone, Advance, or Oreilys autoparts stores. There are some malfunctions which will not set a Code and yours is temperature sensitive, so the scanner will have to catch it at the right temperature.
Looking at the thresholds you have given, there are a few other possibilities. If you look at hard acceleration, manifold pressure drops and you are saying the engine runs smoother with less manifold pressure. Could be a bad MAP sensor. Then looking at temperatures above 75 degrees, pressure in the fuel tank increases and the Evaporative Emissions system must adjust to capture the gas vapors. If the Evaporator solenoid is misfiring you may be feeling it cut-out. You have replaced the fuel pressure regulator, but has the regulator been adjusted? Some systems use a Relay to help the pressure regulator buffer the constant changes in demand to the fuel pump. The Relay could be bad making it seem that the pressure regulator was bad when it actually was not.
Check with one of the above 3 autoparts places for info on this Relay and if your model has it. I hope my solution is very helpful and that your problem is a less expensive part.
Aug 19, 2011 | Ford Ranger Cars & Trucks
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
Model 141.163211 Kenmore BBQ Grill. Burner tube ignites then after a few seconds flames ignite behind control panel - melted knobs. A year ago same problem. Removed all parts and cleaned, installed new...
It sounds like sealant may need to be used on connections. Use appropriate one for gas fittings.
Noting where the leak is occuring is important. Another possibility is the fuel is being somehow "jetted" from a hole or orifice in a burner tube to the area behind the control panel. These are hard to see what happens first when it does happen.
Nov 07, 2009 | Kenmore 16322
Bruner will not heat past 140 degrees, just bought a new tank
I just got done having the same problem. Disconnect the tank. Let the hose hang there for 5 or more minutes to drain any gas. Reattach the hose to the tank. Turn the knob on top of the tank SLOWLY 1/4 of a turn. Light the first burner on the left. Turn the knob on top of the tank another 1/4 turn. Light the rest of the burners from left to right. Don't open the tank valve any more than 1/2 turn altogether. When you changed tanks and hooked up the hose, the regulator in the hose cut back on the flow when the new blast of gas came through. (Its a safety feature.) So draining out the gas from the hose to reset the regulator and turning on the gas SLOWLY should give you good pressure.
Dec 26, 2007 | Kenmore 16322
Kenmore 16322 Logo
558 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
