Question about Dell 5100cn Laser Printer
Dell 5100cn Black Developer Unit
I know I have read a solution in the past that explained how to replace the black developer unit on a Dell 5100cn, but I can't find it now. Can you please list the steps to replace this unit. I really appreciate it.
Thanks,
Scott
Same problem and no parts breakouts to be found
  • Aerator Dec 20, 2008
    Hi, I need a parts break out for replacing the Developer Drive Assembly Part # M6091 - please note, this is not the toner cartridge, nor the developer or fuser or transfer web - it is the drive assembly.
    Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your specific requirement "how to replace the black developer unit on a Dell 5100cn"
Initially in versions available in my country, the following must be removed:
  • the top cover, the left side cover, the high voltage power supply, the supply tubes (this is where the toner travels from the actual toner cartridges down to the developers);
  • the photo developers are located behind the imaging drum;
  • remove the drum to expose the 4 developers;
  • you can see the 4 separate developers in the developer frame;
  • once the tubes are removed, you have to remove the developer frame from the printer;
  • then you can get to the actual photo developer.
Note: Pls be very careful when placing the imaging drum, a flase move and easily damage any of the drumkit.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 17, 2008
  • 2,427 Answers
The instructions are located in the owners manual here is a link to it
ITS FREE
http://office.manualsonline.com/manuals/mfg/dell/dell_printer_product_list.html
Instructions to replace the toner and image transfer drum is in there as well as the laser unit.
Posted on Dec 20, 2008
  • Rishi Roshan Ali Dec 20, 2008
    BTW Benimur has given you detailed instructions he is preety good at these sort of things.
    Sergeant:
    Novelist:
  • 327 Answers
  • 659 Answers
Http://support.dell.com/support/edocs/systems/5100cn/en/OM/om_en.pdf
Goto the above link for the manual on your unit then check out the matinence section for it.
Should help
    Genius:
  • 1,142 Answers
Please refer to this link this will show you step by step how to replace the toner
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section20.html#1092583
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
I'm working on a Dell 5100cn printer. it came in with a yellow developer issue leaking toner. I replaced the yellow developer and cleaned the unit. In the process some of the developers were emptied to...
you have to do is remove all 4 hoses, the single electrical connector at the top of the frame, and then the frame will pull lose from the printer. If you do remove the developer frame, make sure you clean the ROS glass, this is actually the printhead, located behind the frame when removed and as well as other parts. Reopen the black cartridge, set it well and lock it completely. There is a cheap under the toner, make sure that it is not corrupted, if it is, then you should remove it out and replace it with old toner cartridge. If the problem still exists then you can check this web link :
http://support.dell.com/support/edocs/systems/5100cn/en/ug/section20.html.
Apr 08, 2011 | Dell 5100cn Laser Printer
Pages come out pink only when printing in colore
The magenta developer is bad.
The developer drive on this printer rotates in both a clockwise and a counter clockwise direction to turn the developers.
When printing black, ( i cant remember which direction it turns, ) only the black developer turns.
When printing color, the developer drive turns the opposite direction, engaging ALL 4 developers.
( the developers are the multi colored bars you see when you remove the image drum unit.)
This is why you do not get the pink output when printing only black.
your choices are to set the printer to only print black and white. ( you can do this in the printer properties for your print driver). or you will need to replace the magenta developer.
Feb 07, 2011 | Dell 5100cn Laser Printer
Developer drive assembly
That's what you need a developer drive assembly, I've replaced several of these with exact issues. After replacing the part printer prints color.
May 10, 2010 | Dell 5100cn Laser Printer
Printer prints out black very light
First change you photo conductor unit if not solve
change the developer unit ( Ink ) If not solve
Clean the scanner glass of the printer.
Note that don't displace the glass just wash with a white dry cloth
Thanks
Oct 26, 2009 | Dell 5100cn Laser Printer
Dell 5100cn laser printer
Yes, Dell Color Laser 5000 series printers are Xerox printers. Good luck finding the part....
Feb 02, 2009 | Dell 5100cn Laser Printer
You are right. The procedure was initially posted by Corysf62 on this problem. Excerpt from that post:
  • "The photo developers are located behind the imaging drum. you can see the 4 seperate developers, in the developer frame, when you remove the drum unit...You need to remove the top cover, the left side cover, the high voltage power supply, the supply tubes ( where the toner travels from the actual toner cartridges down to the developers ). Then once the tubes are removed, you have to remove the developer frame from the printer. Then you can get to the actual photo developer."
Dec 11, 2008 | Dell 5100cn Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Dell 5100cn printer
The only effect that the "non Dell toner" setting has is to raise the fuser temperature to the maximum. Since all toners are made up of ink and plastic, the fuser is what melts the fine plastic to the paper.
Dell toner is designed to melt at a lower temperature, however, since the non dell toners temperature value is unknow, this setting allows for that unknown.
In any case, neither of these things will cause lite, or faded print. In Fact, the toner cartridge for this model is actually nothing more then a toner storage device. Some cartridges contain the toner, the developer, and the drum. On the 5100 and the 5110 this is not the case.
More then likely, if only the black is printing poorly, and the colors are printing ok, then the black photo developer is defective. This is a very messy job if you do not know what you are doing, and very involved.
Good luck.
Aug 22, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
390 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
