Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Where is the coldest setting on my samsung cooltech?
I am not sure if the coldest setting on my fridge is when the wheel is moved to its furtherest position in a clock wise direction or somewhere in the middle as the indicator lives move from solid to two lines.
The fridge appears not to be cooling to well on hot days so do need to have the coolest setting.
Thanks Jill
  • 5 Answers
SOURCE: Samsung RS2545SH coils freezing
Hey how's it going? I may have the info you need, but first I need you to go through a check list to see if there is a simple fix.
Check to see if there are any obstructions in the freezer drain (freezer drain located inside freezer compartment behind back panel lower right hand corner of the freezer coils) if there are obstructions or debris remove and clean with a mild dish washing detergent and water, check to see that water can drain freely. see if this helps.when the coils freeze is the ice flaky or is it frozen solid ice? if the ice is flaky it could mean that either the refridges/freezer door are left open to long "check your door gaskets or seals by closing the on a dollar bill if it pulls out easily with little to know resistance your door gaskets may need to be replaced. After you defrost the freezer coils did you notice if there was water in the condensor pan, if so good sign. (condensor pan: is the pan that collects the water that drips through the drain hole of the freezer compartment caused by the heating of the coil by the coil heater: water that enters the pan collects and is reused by the condensor fan by blowing warm air partly into the water and through the condensor coils causing them to cool.)if you still need to test your bi-metal therostat or your glass heater/ice pipe heater, you will need a multimeter and knowledge on the use of it.(IF YOU 'RE NOT NOT COMFORTABLE AROUND ELECTRONICS AND ELECTRICITY PLEASE CONTACT A QUALIFIED REPAIR SERVICE AND REMEMBER TO UNPLUG APPLIANCE BEFORE ATTEMPTING ANY REPAIRS) for more info on how to test please reply,Good Luck, be safe..
Posted on Aug 24, 2008
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
SOURCE: Samsung Cooltech fridge - type SR-52NXA - when
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Posted on Apr 06, 2010
iwillfixforu
  • 619 Answers
SOURCE: getting very hot in the middle betweenthe fridge and freezer
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Posted on Apr 27, 2010
Testimonial: "Fan was not running at all ... big help ...thank you"
My Samsung cooltech freezer and refrigerator keeps freezing all the food in the fridge. It also seems like it is leaking from the freezer into the fridge
turn the temp dial in the fridge down if set on on 5 try 3 and see if that works . there have been some makes that the control has failed and needed replaced .
Mar 02, 2015 | Samsung Refrigerators
I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Aug 12, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
I am looking for the replacement parts for a Samsung Cooltech 330 litre fridge. It is the door shelves
Google search for parts for Samsung Cooltech 330.
You will probably find it there
Jul 03, 2008 | Samsung Refrigerators
Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Assistance required
A thermostat would have nothing to do with this problem. Condensation occurs when warm air moves into a cold place. Check door gaskets or any possible way that warm air is getting into the cabinet.
Nov 07, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
