Question about PSC PowerScan RF Base Station
Can't scan label..... i've got some labels in 128 code... when i scan more than 2 times the scanner gets blocked.... so the keyboard too
    Sergeant:
  • 274 Answers
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They'll have your answer.
Posted on Sep 11, 2007
  • Jerry Hess Sep 11, 2007
    Easiest thing to do is "turn on" the logging function and send a report into service. They'll be able to tell you why.
    "Log file" in the last part of your manual.
MC9190 will not scan a certain barcode, but the MC9090 will, what could be the problem?
Firstly you need to know exactly what 'symbology' or type of barcode you are trying to scan. E.G. 128CODE, ect.
Once you know this make sure 'DataWedge' is installed and go to the settings section of the software.ensure that the type of barcode you are printing is selected in the settings. After this is should work.
regards
Dave (Pen Mobile) Germain
Jan 28, 2013 | Zebra Symbol Technologies MC909X-G Series...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
I wish to connect a bar code scanner to my Keyboard Display Unit for inputting data when printing labels. Can you provide information relating to pin outs, protocols and how to set this up? Thanks
By Keyboard / Display unit I'm assuming your using a PC, thin client or dumb terminal. If you are using a PC then the easiest way to do this is to get a bar-code scanner with a USB interface, no programming should be required with possibly the exception being of adding a "Enter" (CR LR) after each scan.
If you have a dumb terminal then you may need to look at trying to use an RS232 connection (if one exists) or a keyboard wedge solution where the scanner is plugged into the keyboard port along with the keyboard.
In any event pin outs would vary depending upon the scanner you want to use and the device you are connecting the scanner to.
Hope this helps
mikeo@acebarcode.com
Mar 02, 2011 | Zebra Eltron LP 2824 Thermal Printer
Our company has several Zebra printers that print out barcodes that are scanned using handheld scanners for many things including inventory management. The labels that come from ONE of these Zebras...
Power off printer. Press and hold pause button while power on. This will print dark black line across the entire label. Check for white vertical lines. If you see any in the area of the label where you are experiencing a problem then the printhead should be replaced. Power off and on to exit diagnostics.
Jun 25, 2010 | Zebra 105SL Thermal Label Printer
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
May 13, 2008 | Symbol Hotshot LS2106 Handheld
PSC PowerScan RF Base Station Logo
255 people viewed this question
Top PSC Computers & Internet Experts
Tom Chichester
Terry
Terry
Paul Jones
Paul Jones
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
