Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Switching fax machine from telephone to fax
The window is saying telephone on panasonic uf490. i can send out faxes, but cannot receive them. customers are saying they are only getting a busy signal. help, and thanks.
I just had a similar problem... On the upper Rt. hand corner of the #'s keypad is located an "In / Out"
pushbutton switch. There are 2 options. 1.) Rec'v Mode = Tel, or 2.) Rec'v Mode = FAX. Select
FAX option.
Posted on Apr 21, 2009
    Genius:
  • 2,120 Answers
Make sure you are NOT plugged into the port that has a picture of a telephone it.
press
Function 74
set
15
set
choose fax
set
stop
unplug the power cord for 10 seconds.
Posted on Dec 18, 2008
How do i receive the fax directly to the pc without the internet ?
From what you are saying. I believe you are trying to receive (or send) a Fax directly to your PC but NOT being connected to the Internet. That is...receive a fax on your telephone line.. This IS possible but you need what we had in the old days called a "Fax Modem" on a PC card to be installed in one of the spare slots inside your PC to which you plug your Telephone line..
Windows has ALWAYS had the feature but you need the Hardware Modem to do it'
See here on how to do it. http://windows.microsoft.com/en-us/windows7/products/features/windows-fax-and-scan
Sep 03, 2014 | Panasonic Uf-8300 Laser Fax Machine
Just checking..we have a brother fax Intellfax 4750 and we can send out faxes however no faxes are coming in. It says receiving on the display but ringing in busy from the person sending the fax...any...
Call your fax machine from a telephone...have someone watch your fax and see if it answers...also listen on the telephone and see if you get the "tones" that a fax gives.....if your fax just keeps ringing then it just may have been set to the "tel" (telephone) mode...set it back to the Fax mode.
Oct 25, 2010 | Office Equipment & Supplies
Clear memory for the fax machine panasonic uf490
Hi
Right!!!
Press 'Function' then 7
Press 'Monitor' seven times
Press '*' (star)then 0
This Gets you into service mode.Scroll down on using Large Round Button until you get one that says Ram Initialize press Start then Scroll down unitil you see All job Clear,then press start again,M/c will reboot and this should clear your memory.
Powerdown once then your memory% should disapear
Good Luck!!
Sep 21, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Cannot receive a fax but can send one out
Make sure your phone lin is plugged in the jack on the machine that says LINE not the jack that says TEL or PHONE. I have seen this before. the unit gets a dial tone and can send but will not answer.
Hope this helps
Mar 11, 2009 | Canon Office Equipment & Supplies
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Jun 08, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax wont send
try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
Feb 27, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
119 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
