Question about Kenmore 22422 Top Load Washer
1. I need a manual for a USED washer I purchased Kenmore 70 series-model 20712990, type 111? 2. I need to know where to put the fabric softener...the lid says to "addd to the agitator-mounted dispensor", but I do not see a dispensor mounted anywhere. Thanks
  • paulettafrit Dec 19, 2008
    Thanks! I did call Sears, and they were able to not only show me how to download the manual, but also handled my Fabric Softener Dispenser problem...seems they have a part that attaches where the cap on my agitator is , and they are mailing it out to me. The part and the Shipping and handling total around $15.
  • 8,197 Answers
I just bought this washer and dont know where to put the soap and softener
If the model number is correct, the detergent and fabric softener go in the dispenser drawer on the left hand side of the operator console. Detergent goes in the LEFT FRONT compartment and softener goes in the RIGHT FRONT compartment. A full explanation of the dispener compartments is included on about page 13 of the owner's manual. If you do not have an owner's manual, you can obtain a FREE copy at managemylife.com. Just type in your MODEL NUMBER under their "Manuals" link and your manual is available in .pdf (Adobe) format that you can download or print for FREE. If you have any questions, please post back and let me know. I hope this helps you.
Jul 19, 2010 | Kenmore Elite 45986 Front Load Washer
Does the fabric softener dispensar come apart?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7914776481dcf14414831964a8792e18
Depending on the model, your fabric softener may have a ring around its bottom. Push down or pull up the ring and the dispenser should pull straight up. It doesn't twist off.
Also see the following Sears site. It may have an on-line manual for your machine.
http://www.managemyhome.com/
Mar 20, 2010 | Kenmore 22422 Top Load Washer
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
IF THE MOTOR DOES NOT RUN CHECK THE LID SWITCH. IF YOU HEAR IT RUNNING YOU MAY HAVE A BAD COUPLER.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Kenmore Washing Machines
Dual action kenmore 70 series washer need to remove agitator
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
WHERE DO I PUT FABRIC SOFTNER
Hi, If there isn't a softener container in the top of the agitator, you can get a softener ball from your local grocery store. Just put the softener in before you wash and it will open to release the softener during the spin cycle. It works great. I use it all the time.
I hope this helps. Please let me know if I can assist you further
Vic
May 20, 2009 | Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I just bought a used Kenmore 70 series washer, model #20712990. It will fill and agitate, but after that it seems to get stuck "soaking." I moved the timer forward to rinse, and it agitated again, but it...
all that is wrong is the lid switch is bad,remove the 2 head screws one on each side,flip the head up,you will see the lid switch jack on the washer top,unplug it clip the two outside wires and wire them together(unplug the washer first before you start this)now plug the jack back in,you have now by passed the lid switch and your good to go,let me know how you do-mike
Mar 21, 2009 | Kenmore Washing Machines
I need help also.
The model number should be located around the tub opening somewhere. The part you are describing sounds like the lid strike and/or lid switch. If you can doublecheck and provide me with a model number, I can locate the parts for you. If you wish to repair this yourself I have step-by-step instructions at the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch usually costs about $25, while the lid strike costs about $10. A repair of about $35 may change your mind about buying a new one. I hope this helps you. Post back if you have further questions, or need more assistance.
Apr 28, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
627 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
