Question about Compaq Evo N610C Notebook
Can't get power back on after battery went flat
Although the power input (18.5 volts-checked it) is plugged in cannot get a green power light.
  • 2 more comments
  • tblakley Dec 26, 2008
    Compaq Evo N610C PC Notebook
    I am dealing with the same problem with the same computer, must be a malfunction. I even went and bought a new battery charger, I can't get the green light to come on for it to charge.
  • hjtovey Dec 26, 2008
    I fiddled about with the input plug to the computer and eventually got a yellow light which I think meant that the battery was charging-after a time, presu,ably when the battery was sufficiently chatrrged the green lights cam on and I was able to log in. In other words, it was a faulty connection
  • JDTec
    JDTec May 11, 2010
    The DC connector on the system board is probably loose and needs to be resoldered.
I have the same notebook and the same problem occurs with mine. First you have to disconect the battery a few times in a row. You may have to tremove the bios battery. If you have the extra battery in the socket where the cd player is then you need to remove that battery as well. I have this issue with my laptop on a regular basis and thats what i do to fix the issue. watch out for heating up issues you can't use this unit flat on your lap for a long period of time it will heat up and random shut off, you should get a cooling fan tray from e-bay i got one with 3 fans for 11 dollars i also recomend going into the bios and setting the fan to always on when pluged in thjis helps keep the unit cool and working. When you get the light to come on i sugest letting the battery charge up before using the unit.
Posted on Apr 13, 2009
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
The battery on my Worx GT doesn't seem to hold it's charge. I have actually taken it directly off the charger when the light is green and it doesn't have full power. Sometimes it does. The unit is 3...
the first time the Worx GT worked great since then I took it off the charger and it won't go more than five min. without going dead. I'm back using my gas trimmer what's up ith th battery on the Worx Gt
Jul 16, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
Plugged into rental mini van; powered up converter; light turned green; plugged in 2 different Dell laptops and both times light on converter went from green to red and lap top confirmed not receiving...
Try to measure the input voltage. If the Vans battery falls to less than 10.5 V it may stop converting. The battery should be charged well before using converter.
Jun 10, 2010 | Black & Decker 200 Watt Power Inverter
Compag presario will not start
Try the following possible solutions:
1. Unplug the power from your computer for 15 minutes.
2. If your computer is plugged in via a surge protector, plug your computer into the power outlet directly, maybe you are dealing with a faulty surge protector.
3. Near the plug where the power plugs into the back of your computer, there is a little switch where you can choose between 120 volts (USA) and 220 Volts (Europe) as input. Make your this did not inadvertently get changed to 220 Volts.
If neither one of these solves your problem, please let me know so I can assist you further. Also, how old is this computer?
Thanks for using the fixya forums!
Mar 30, 2009 | Compaq Computers & Internet
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
18 volt milwaukee batteries
You could try another battery if you have on(they only last for so many charges) or your charger could be bad. Try plugging it in to another outlet. Good Luck
Oct 15, 2008 | Milwaukee 6310 22 18 Volt 6 1/2 In....
Acer aspire 3004 WLCi won't power on
Often times when laptop won't power on, it's jack on the back where the power supply plugs in. It needs to be disassembled, soldered back together and that should fix it. Good luck!
Aug 22, 2008 | Computers & Internet
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Jun 30, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Green light keeps blinking? Any clues
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 23, 2007 | Mitsubishi WS-65613 65" Rear Projection...
My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Jan 30, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Compaq Evo N610C Notebook Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
