Question about Maytag Kitchen Ranges
Maytag range model #cre8600acl has a F-2 and F-3 error code and beeps
catriver
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Posted on Jun 05, 2007
Dipu007
  • 2110 Answers
SOURCE: F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Dec 23, 2008
  • 25 Answers
SOURCE: Jenn air range model SCE30600B error code FC
replace oven sensor.
Posted on Feb 12, 2009
SOURCE: "F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Posted on Aug 11, 2009
localwonder
  • 6784 Answers
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Posted on Nov 08, 2009
Code f10 and f29 came up while On self cleaning what does this mean ?
Washer Error Codes Below is a list of... - Elite Appliance ...
https://www.facebook.com/permalink.php?story_fbid...id...
Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, ... Check pump trap and clean. ... Musical series of beeps every 5 seconds and Wash cycle light flashing-Washer is overloaded. ... E47--Board thinks the door PTC circuit is open in spin .... F29--Door unlock error
Range Error Code F10: Troubleshooting Runaway Oven ...
? 2:20
https://www.youtube.com/watch?v=z6tcnpDKDns
Oct 1, 2015 - Uploaded by searspartsdirect
If you see F10 on your range, it means that your electroni. ... exceeds the temperature you set it at in either .
Nov 07, 2015 | Electrolux E30EW85EPS Electric Kitchen...
Maytag gemini model MER6770 AAW error codes F 1-2 and F 3-2
Sounds like a heat sensor and limit switch problem, but it could also be a control board failure which is also pretty common in Maytag appliances. Lately any Maytag i have issues with, dishwasher, range, clothes washer, etc, usually leads to a bad control board. But if the sensors are cheap enough i would try swapping them first and making sure connections are good on everything, thats the cheaper first step compared to replacing the control board.
May 04, 2017 | GE Profile J2B915 Dual Fuel (Electric and...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I have an old maytag gas range model number CRG9700AAW, that beeps with an "F7" on the display, any idea what this alarm is?
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Maytag Kitchen Ranges
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
Maytag mgr6775ags is beeping very 20 min. I press the cancel button and turn off the eletric the range still beeping when the eletric is off.
Is your range giving you an error code? If so, please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM - 7 PM with your model number and we will be happy to give you a free disgnosis for this problem.
We are factory authorized Maytag service technicians and will send you parts removal/installation instructions when you purchase your parts through us.
We look forward to working with yo and getting your range in working condition again soon.
Thank you, Ella
Mar 10, 2010 | Maytag Kitchen Ranges
Maytag Oven MEW5530BAW throws error F1 after cleaning the oven using the clean cycle. I had to manually unlock the door and tried to run oven afterwards but it is still throwing the error
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Importatnt. few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 07, 2010 | Kitchen Ranges
Kitchen Ranges Logo
164 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
