Question about Sharp Aquos LC-15E1U 15 in. LCD EDTV
Problem with power on
When I turned on my Sharp Aquos LCD this evening from the remote control, the red light turned green, I heard a click at the back of the TV and the light went red again. I have checked through the manual at the troubleshooting section but is of no help. Hope you can help.
  • 1 more comment
  • Anonymous Mar 15, 2014
    When first switched on using Main Unit Control Section after 2 years unused the standby/on indicator turned red and then switched on again turned green and then orange. There was a brief flash of light on the screen. Now the indicator turns red and then orange and the screen remains dark.
  • Anonymous Mar 18, 2014
    TV was on left the room and it was off. Turned V back on and 15 minutes later it went off again. Tried another time and it will not come on. White light is flashing at the bottom of the tv
  • Anonymous Mar 29, 2014
    WILL NOT TURN ON ALTHOUGH I GET A GREEN POVER LIGHT ON TV AS WELL AS CONTROL BOX (UNIT)
    President:
  • 3,130 Answers
No you have a power supply problem on this TV set. Pretty common for this make as the capacitors and the regulator circuit In my opinion is way under rated, as there is no head room on the power supply in cases of when the screen turns really bright, or you could have a ballist problem in your backlight circuit. All of these are non repairable by the user unless you have solid state repair experience. Good Luck
Posted on Mar 26, 2007
SOURCE:
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp tv remote control problem
Keep your mobile camera on press any key from remote you will get flash light in mobile.It means remote is ok.
Press On/Off switch from LED Tv and checked tv is on or off.
If Green light is blinking but tv not getting on follow as per attached file.
Mar 31, 2015 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Apr 02, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp Aquos 36 in. HDMI LCD
remote ceased functioning! What did I do...and how do I undo it?
Oct 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
** picture - solid green power light - relay clicks
yes,the set has a main video processor board bad.Sharp is well aware of this problem,and with persistence sharp will give in.
Mar 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-15E1U 15 in. LCD EDTV Logo
189 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
