Question about Nikon LS 2000 Film Scanner
I need to connect a Nikon LS2000 Slide Scanner to a Power Mac G4
I need to find a SCSI cable to connect my Nikon LS 2000 to my Power Mac G4
  • karen512 Jan 10, 2009
    ineed to connect to a HP pavilion dv5-1000us running vist
I originally had the same problem but with a G5. Since Nikon never updated the software for the LS2000 to work with Apple I ended up buying a FR1SX adapter from RATOC Systems: http://www.ratocsystems.com/english/products/FR1SX.htmlwhich connects the SCSI pins to a Firewire cable. Then I purchased the VueScan software from http://www.hamrick.com/vsm.html. The scanner worked for several years with this combination.
Posted on Dec 24, 2008
I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
http://www.pcreview.co.uk/forums/thread-1936922.php
Dec 03, 2009 | Nikon LS 2000 Film Scanner
Nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Mar 22, 2009 | Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Can I connect a Nikon LS200 to my Mac PowerBook G4
Nikon supports mac. You'll want to go to nikon.com for more details.
Jun 04, 2008 | Nikon LS 2000 Film Scanner
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software (www.hamrick.com). This works perfectly on LS2000 - Macbook Pro combo.
Jun 02, 2008 | Nikon LS 2000 Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Drivers for Nikon LS 1000
I believe that's a SCSI-interface scanner, making its setup more complicated than there's room for here. Here's what Nikon says about SCSI setups: <http://tinyurl.com/2wxp7p> and the Nikon software for the LS2000 and LS3000 (but maybe it'll work for the LS1000 too) is at <http://tinyurl.com/2qko5e>. There's a good set of detailed installation instructions under cineman's entry at <http://hardware.mcse.ms/archive47-2005-6-203500.html>. Good luck!
Lenny
Feb 11, 2008 | Photography
NIKON LS2000 SCANNER
this scan works with SCSI interface not provided by default in PC. So scan uses to come with SCSI board .. you need to install it into your PC .. yes
Nov 19, 2007 | Nikon LS 2000 Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Nikon LS 2000 Film Scanner Logo
580 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
