Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock on, won't come off. Washer won't work. also get F2
But don't know how to open the front. It is a GHW9100LW!: CSM4406954: 199PWM675gy
On the F2 error, I put the hose out the window and it still says it has a blockage, but as stated I don't know how to open the front.
Judy
  • 100 Answers
Just click the link
http://www.applianceaid.com/duet_washer.html
its mentioned it it.
Posted on Dec 17, 2008
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 20, 2012 | Electrolux Eiflw55hiw Front Load Washer...
Whirlpool duet ghw9100lw lights on, not locked and still won't start
Just above where the washer door strike goes into the latch is a small round piece of plastic that activates a switch in the latch- is that still there? It will push in and come out as it is spring-loaded.
Oct 22, 2012 | Whirlpool Washing Machines
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Washer won't start
could bea wide range of items since we don't have any description at all. does it have a display when you turn on or is it blank? does the door lock buzz or appear to be locking door. is it totally dead and have you checked power at plug to make sure a breaker hasnt tripped. the control assemblies on these are fragile and could be bad ,but before stating that need more info...
Dec 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet GHW9100LW won't start, won't give error code. No locking noise when trying to start, and makes a couple of clicks "in the back" when pressing start in troubleshoot mode. No...
Hi, I've only just come on line to see and glad that you have identified the problem yourself- as you say persistence pays. I'm not even sure that I would have been able to suggest anything myself other than 'are you sure the lock and sensor are physically working?' ;-0) John C
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Duet GHW9100LW I turn it on and the dial light just blinks, it does not lock or start. Tried unplugging, did not work. Don't have manual. Is there a reset button?
Could be a bad lock or possibly a bad control board. I run into this all the time, working for a maytag/whirlpool dealer and repair facility. If your in a area that has alot of power outtages or surges get a surge protector after you get your problem fixed.
Feb 19, 2011 | Whirlpool GHW9150 Front Load Washer
I have a GHW9100LW. It is control locked. How do
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Feb 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 02 whirlpool duet GHW9100LW?
unplug for 5 minutes then plug back in see if it resets itself,also check the door switch on inside of the door on washer make sure that has a clicking sound,sometimes on some models if the door switch goes bad it will not spin or drain,let me know,thanks-mike
Jul 26, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
