Question about Acer Aspire 9300 Notebook
Acer Aspire 9300 - Broken DC Charging Jack Socket
Managed to take it all apart and reveal the keyboard. How do I get the keyboard off to get to the DC power socket? On gently lifting the keyboard, the connecting cables are so short I cannot reach the plugs to release the keyboard and may not be able to get the connectors back in afterwards. Thanks & Regards, Ron
  • Anonymous Mar 28, 2014
    Green light on adaptor stable but no dc current at DCjack.Tried another adaptor but with3.16A output nothing happened.Replaced Dcjack with cable nada.There is a visible (melted plastic)next to c104 I think.Do I need a replacement mb or do you think it can be fixed?If it does I can break it apart and get back with details.Best regards and many thanks.
You will need to disconnect these. Then you will locate the five metal tabs along the back, which need to be pressed in, which releases the top part of the keyboard and it will now come out. Then re assemble connectors through the access holes you will now see very tricky job more plug connectors inside to so go carefull make sure you disconnect these correctly as you may pull the wires out
Posted on Feb 08, 2009
How to remove my keyboard from an acer aspire 7520-5185 laptop?
Slide back the 6 tabs away from the keyboard (as show here, be sure to turn down the volume!~: https://www.youtube.com/watch?v=0d4p3obsjHQ ). Lift up the keyboard about 3 inches to reveal the data strip attached to the keyboard. Lift up on the brown data strip gently, as these have a tendency to break, if forced. Reverse the process with the install of the new keyboard, save the tabs: Just apply pressure at the top of the keyboard, on the corners first, and they will snap into place.
Apr 07, 2015 | Acer Computers & Internet
Instrutions how to replace charging port aspire 6935g
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 6935g jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 16, 2014 | Acer Aspire Computers & Internet
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Jun 02, 2014 | Acer Aspire 5315 Notebook
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
Dgx 230 dc in connector bad
This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
If you need a socket Google :
Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
Yahama PSRE413 Keyboard DC Adapter Issues
Yahama PSRE413 Keyboard DC Adapter Issues (1): First try battery power to ensure Synth works.
If it does, problem is most likely near DC socket, or socket contacts dirty / worn.
(2): Get a contact-cleaner spray (Servisol, McKenic, Kontakt, etc) and squirt into socket, then plug / unplug / twist DC plug to 'scrub' the contacts.
(3): Get a qualified tech to manually apply DC to the PCB solder-points which will verify if socket is faulty.
Aug 10, 2017 | Yamaha PSRE413 Keyboard
Broken dc jack on acer 3003ln
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
Apr 21, 2012 | Acer Aspire 3000 Notebook
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
The dc power jack will not accept power. I have to wiggle it to get the blue light to show that the laptop is charging. My computer is the acer aspire 5920-6423. I was told it wouldn't have to soldered...
If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.
The laptop needs the motherboard removed to get access to the DC jack so it can be resoldered or replaced if it is faulty.
This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 03, 2011 | Acer Aspire 5920-6727 Notebook
Acer Aspire 9300 Notebook Logo
427 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
