Question about Sony KV-27S65 27" TV
Your assistance sony 27 " tv serial number 8034983 and model number kv-27s65 there are two diodes near the converter tuner circuit numbers d250 and d251 that are open i am not sure if there are zener diodes or normal all purpose diodes i therefore need your assistance in knowing there values if there are zener diodes your assistance will be appreciated
  • lenny lalor Mar 30, 2007
    i appreciate the quick responce i tried the 9.1 zener diodes but the tv screen will not light up and there is no sound it however light with the open zeners or when i remove one leg of both zeners i however figure if the values are right there is another problem in the circuit somewhere
    President:
  • 3,130 Answers
The Sony part number for these diodes is 8-719-108-12 and yes they are 9.1 volt zener diodes @ 1 watt. I have the service manual for this set if you need it put can only send a large file like this trough a proggy called pand, so if you go to pando.com and get the proggy and leave youe e-mail addy I will send you a copy of this service manual. Good Luck
Posted on Mar 27, 2007
How can I find a primary tuner for a Sony Trinitron Tv' Model No. KV 27S35. It was manufactured in January 1997?
The tuner is Sony part number 8-598-340-00. This site says they have it for around $35. Their stock number is 72-1001.
Jul 05, 2011 | Sony KV-27S35 27" TV
Sony KV-27S65 27" Television suddenly has very low volume
that problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Jun 03, 2010 | Sony KV-27S65 27" TV
Sony KV-27S10 has intermittent tuner issues. moving the cable connection on the back of the set sometimes clears the picture.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KV-27S10 27" TV
I need code for programing a universal TV remote control
You should be able to find the remote control code at this website. Good Luck→
http://www.tvcodes.com/index.html
Mar 22, 2009 | Sony KV-27S65 27" TV
Panasonic tv help
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Jan 24, 2008 | Sony KV-27S65 27" TV
Assistance for a match for flyback
HI
Is the original flyback number: fcm20a025? I work in a shop repairing televisions, might have a good spare I could send you.
Mark
Nov 05, 2007 | Sony KV-27S65 27" TV
Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Aug 13, 2007 | Sony KV-36FS17 36" TV
Your assistance in solving this problem
helo your problem is very easy try to adjust the I F control along jungle section. hope you can make it
May 29, 2007 | Sony KV-27S65 27" TV
Part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
Mar 13, 2007 | Sony KV-27S65 27" TV
Sony KV-27S65 27" TV Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
