Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction I purchased my Dyson about a year ago and it has worked great, but recently the suction when vacuuming carpets and floors is very poor. The hose still works as it did when I purchased the vacuum. I have taken the vacuum apart and see no clogging in any compartment, can you tell me what could be causing this problem? Thanks
  • 4 more comments
  • Hillyt Nov 15, 2007
    having the same troble. It is almost like the auto carpet height adjustment is off, but I cannot find a way to adjust it.
  • nettyd57 Jul 24, 2008
    I have the same problem - my hose was torn but was able to salvage with duct tape - took it all apart and still no suction. Disheartening for a vacuum that is marketed as never loosing suction.
  • Anonymous Jul 31, 2008
    sucking power is poor
  • jackell Jan 07, 2009
    The suction in my vacuum does not work. The hose is clear, it will not pick up
  • Anonymous Mar 18, 2014
    Suction to strong sticking to floor can't move vacuum forward
  • Anonymous Mar 23, 2014
    I purchased a Dyson vacuum on 1/15/14 and the store had a Free DC34 handheld offer but purchase date needed to be between 12/8/13 and 12/24/13. Would it be possible to honor the offer?
    Problem Solver:
  • 4 Answers
Might be the hepa filter needs cleaning? This is located in the housing on the side of the cleaner at the bottom (see your manual to find it). It is a big spongy ring which Dyson say you should remove once a month and wash in warm water. Dry off and replace in cleaner when completely dry. I've found this works and the suction is like that of a new machine!
Posted on Dec 19, 2007
    President:
  • 1,462 Answers
Check the filters as well as hoses. filters need replacing regularly or at least cleaning
Posted on Mar 27, 2007
The picture says do not use water on the filter.
Posted on Dec 27, 2007
I can think of 2 things first do"s the clutch{ if it has one}work or is it in the off postion you can test this by lying the dyson on it"s side and turning it on but remember to push down on the bottom as if you was hoovering if the brush spins then its ok if it dosen" move then replace it second take the bucket off and remove the bin tune it upside down and see if it is blocked if so the best way to clean it is to sit it upside down and put a hose pipe in then just wait till the water runs clean hope this is some use to you
Posted on May 22, 2007
My Dyson DC14 picks up on hard floors and the hose works, but lacking suction on carpet
The DC14 has belts in the clutch that become stretched and lose elasticity. Even with great suction a vacuum will not clean well on carpet if the brush is not spinning fast enough.
Mar 04, 2018 | Dyson Vacuums
Can the suction be adjusted manually as it is too powerful on my carpets
returns are up to the place of purchase. we can not answer that for them. contact the place of purchase.
the suction can not be adjusted.
Jun 25, 2016 | Dyson DC40 Multi-floor Vacuum DC40
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Too much suction on smooth surface
Check the wheels on the bottom plate to make sure they are not allowing the bottom to sit flat on the floor. The wheels must keep maintain a gap between the plate and floor or it will suck down like a suction cup.
Jan 26, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
My dyson will not pick up but has suction when using hose only
I have had Dyson All Floors model,( the one with the clutch adjustment to allow transition from carpet to hard floor) for a number of years. Recently pick up from carpet particularly poor. Went through all the solutions as recommended on Dyson website. No blockages, no broken sole plate, bristles (should be around 7mm to 8mm long) protruding ok from soleplate ( these can wear slightly over time but not usually the problem), belt not broken nor slipping. Filters cleaned/ replaced, but still poor pickup. Checking for strength of suction, as recommended by Dyson, both at top of hose and at bottom right inlet revealed no problem there. It turned out the clear inlet hose coming from the soleplate to the underside of the machine was the problem from two viewpoints. Firstly, as can be expected, the clear hose can develop splits after a number of years due to wear and tear. The other, not so obvious, problem is that the hose is also a form of straight spring which is designed to be compressed to a certain degree to an S shape when the machine is in the upright position. Upon pulling the handle back, whilst pushing on the footrest at the bottom results in pressure from the hose/spring being applied to the rear of the sole plate, pushing it on to the carpet. Thereafter the suction takes over, keeping the soleplate firmly fixed to the carpet. The existing hose on my machine had settled in to an S shape over the several years I have had the machine, thereby not pushing firmly enough the rear of the soleplate on to the carpet ( I noticed a significant gap at the rear whilst using the machine). For the couple of splits I had effected a temporary repair using a couple of very narrow strips of Gaffa tape, whilst awaiting the new hose/spring, but only a marginal' if any, improvement. Upon receiving and attaching the new hose/spring the solepate was properly pressed onto the surface of the carpet and pickup was like new.
May 09, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Vacuum won't **** in upright position, but there is suction from the hose in the upright position
theres a knob that switches it from floors to carpet turn the to floors.please leave feedback
May 03, 2009 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
525 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
