Question about Food Mixers
Hamilton Beach Model 25 mixer overheating
I have a Hamilton Beach Model 25 mixer that is overheating. It does this everytime I use it, not just with very thick dough.
Someone suggested to me that it might need lubricating, but I see no lubrication point.
Any suggestions, either to repair myself or send out to an expert?
  • sumc144 Jan 19, 2009
    I have the same problem - or at least I did. the turntable (white part) cracked, so I haven't been able to use it for a while
SOURCE: k45 started smoking while mixing cookie dough
plug off the mixer
do you smell or see any smoke ?
if so the motor is burning due to the leakage of liquid on it
Posted on Dec 14, 2007
  • 20 Answers
SOURCE: Replacement beaters for Hamilton Beach Hand/Stand Mixer Model 64586
Call the factory. they will point you in the right direction. number online!
Posted on Apr 11, 2008
  • 5 Answers
SOURCE: Hamilton Beach Model 27 (antique milkshake blender)
First off, check the supply cord. They usually dry out and the insulation crumbles, particularly at the point where they enter the body or motor. They short out. I've replaced cords on antique stand mixers I own. It can be a tricky operation.
Is the motor seized? Can you turn it by hand? (NOT plugged in, of course.)
If all else fails, send it to me and I'll fix it for a reasonable fee, if it is fixable at all.
dudeboy
Posted on Nov 24, 2008
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
ricardok45
  • 135 Answers
SOURCE: kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 25, 2009
I NEED THE BEATERS FOR A HAMILTON BEACH MIXER MODEL 60
Hamilton Beach would be a good source for the beaters or information on where to obtain them
Mar 26, 2013 | Hamilton Beach Food Mixers
Hamilton Beach mixer model 60600
I also need replacement beaters for 60600 HB mixer.
Apr 22, 2010 | Hamilton Beach Food Mixers
Want to appraise my Hamilton Beach Model E 1936 Mixer 15 speeds
e bay is allways a good place to start . but from what i have seen unless its a real "cream puff" 25.00 -50.00 is all your going to get .... you might just keep it right now ..... prices are real low ,people are not buying ANYTHING .........good luck
Jan 14, 2009 | Food Mixers
Stand Mixer
Model H was discontinued in the 70's. You might find beaters either directly from Hamilton Beach or on Ebay. There aren't many small appliance repair shops any more, everything now, is considered disposable.
Jan 02, 2009 | Hamilton Beach 950 Stand Mixer
Apr 07, 2008 | Food Mixers
Food Mixers Logo
248 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Food Mixer Expert? Answer questions, earn points and help others
