I can't find the 16 volt P lamps for the Nakamichi 410 and 420.
Would you know who might have them? Thanks.
Rick
    New Friend:
  • 59 Answers
Rick, If you look in the yellow pages under 'Electronic Equipment and Supplies- Dealers' And take 'em the old one, odds are they'll have something that will work. Radio Shack may even come close. Good Luck!
Posted on Dec 18, 2008
Would a nakamichi soundspace 8 subwoofer work on a soundspace 9. I think the power is the same. Thanks Hugo
Nop, don't do that, the subwoofer power in the Nakamichi Soundspace 8 is 20 Watts and the subwoofer for Nakamichi Soundspace 9 is 70 Watts. If you put the 20 Watts Subwoofer on a 70 Watts input the subwoofer will receive severe damage. http://www.nakamichi.com/pdf/SS8_brochure.pdf
http://www.nakamichi.com/pdf/SS%209%20Brochure.pdf
Jan 29, 2016 | Nakamichi SoundSpace 9 CD Shelf System
Trying to set up Bose 901 series VI to a Nakamichi AV 500 also what gauge speaker wire from amp to speakers
Plain old 18ga lamp cord is fine unless the run is long (over 50', say). Then use 16 ga. Be sure to observe correct phase. Speaker wire is color coded, lamp cord has a ridge on one side. Be sure to always connect the same color or ridge to the same connection (ex: red on amp to copper color wire to red or + on speaker). Do not use "speaker wire" that is smaller than 18go (higher number = smaller).
Jun 25, 2015 | Bose Audio Players & Recorders
Value of the power supply block capacitors in nakamichi re 10 receiver
calculate & fix - circuit volt*1.41= ***
flow - 220v * 1.41 =310.volt above capacitor.
May 28, 2012 | Nakamichi RE-10 Receiver
Naka 700ZXL- Intermittent Problem: After turning on the deck and at the same time the reel motor turns to eliminate tape slack one or more of the 15 lamps on the RAMM indicator panel turn on. If you...
from what is described of the lamps and the RAMM indicator the the negative 4.5 volt supply and the sometimes double spiked signal sound as though you have a weak regulator component or a voltage control circuit with a bad or weak component that needs replacement.
1. check electrolytic caps
2. all diodes/ resistance > all dropped/ no voltage in the voltage controlled circuit
3. trace voltage and current back to source to see if the supply is correct.\
If this is intermittent it means that a component or several components are growing weak and need replacement
4. a schematic for the unit is very helpful in isolating circuit component failure.
Jul 03, 2011 | Nakamichi Audio Players & Recorders
I'm replacing a EGR Valve on my 1997 Ford Escort, what I need to know is what size wrench to remove the tube from the bottom of the egr valve. thanks Rick
Measure the nut
15/16" 1" 1 1/16" or 1 1/8"
Not sure if they are a standard or common size
on most EGR Valves
Not Metric
Apr 06, 2011 | 1997 Ford Escort
Need wiring diagram for older (DB1210) AM/FM/CD player. It has what wires what on bottom but, I don't have plug for it to know which wire is which. Thank you for any help, Rick
Rick, your best solution may be to open the stereo up. In some late model stereos the board is labeled. For example you may see +B, for +12 volt, ign for ignition, gd for ground, etc., I will try to find more information for you but try the above and see if it helps. Thanks.
May 27, 2010 | Namsung Car Audio & Video
No sound to left channel on my nakamichi soundspace 8
Hi Sean....
Have you check the digital balance control? and , have your tried another speaker in the place where you're NOT getting sound?
Let me know...Thanks
Feb 18, 2009 | Nakamichi SoundSpace 8 CD Player
Nakamichi 680zx, no Naka Auto Azmuth control ?, should happer on its own.
Dear all Hi! I am a electronics engineer and I have Nakamichi 680ZX cassette deck, its FL indicators are not functioning. I had checked for both channels output signals on switch PCB. I had received audio signal on pin # 5 of IC 904 (RC4560D) on Indicator PCB C ***'y, further no signal on pin # 7 but (-)10 Volts DC with respect to ground, of the same IC. I would appreciate if you could guide me to rectify the problem. Please also note that I have complete full service manual for Nakamichi 680ZX. Best Regards Muhammad Ali Shah
Senior Manager Service & Technical Support
AVS, Lahore Pakistan
Cell # 0300-8859964
Jun 24, 2008 | Nakamichi Audio Players & Recorders
Where can i buy a head unit harness for nakamichi ta25 thanks
try ebay, i know thats not the greatest thing to say but yeah
Jun 04, 2008 | Nakamichi Car Audio & Video
MB-100
Where about are you? I'm in London UK and do have MB100 HU in my car. I could get you the manual photo copied for you. Let me know and we will take it from there. Chandru
Dec 21, 2007 | Nakamichi MB-100 6-Disc CD Changer
110 people viewed this question
 Grubhead
Grubhead
