Question about Kenmore Washing Machines
Washer doesn't fill with water. Only enough for a small load.
When filling for a load, the water level only rises to about half full for a maximun load. When selecting a medium load, it only fills enough for a very small load. Resetting the level only adds about 2 to 5 seconds more water.
  • 100 Answers
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Posted on Dec 17, 2008
I have a GE /G102 top load washer. When washing a full load I select the SUPER & DEEP FILL levels but my machine only fills up half way. Why?
you may find that the water sensor is not operating fully take the back off the machine look for a small 5mm pipe at the bottom of the drum that
leads upwards take it off blow gently into it you should hear several clicks and when you release the air if so then the place where you took the pipe from is partially blocked not allowing enough air in to switch to the higher load level clean the pipe out with a pipe cleaner or a small rod replace the pipe and try again eric
Dec 28, 2017 | GE Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Washing Machine wont recoginze the load amount to fill with water, ex..small, med, it justs keep filling up to the brim??
Sounds like your problem is one of three things. Most common is that you have to "reset" the water level. This is done by turning the water level knob passed the large load size, and then down to small. Any time you want to go to a smaller sized load, you have to do this. Another possibility is that the pressure switch is bad, this is an easy fix (although not as easy as the reset) The switch can be purchased thru a local parts supply house. And the last thing could be a bad water valve. This will leak and continue to fill the washer after it is already full, this however is usually followed with water all over the floor. If it is not the reset, write me back and I'll walk you thru the other repairs. Hope this helps!
Dec 08, 2009 | Maytag Performa PAV2200
Our kenmore elite frontload washer drains too soon
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not fill all the way.
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
May 15, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
191 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
