Hatachi 53fdx20b I have this television set and it has recently gone out of convergence with the red. I have replaced the stk392-110 chips as well as RK41 which was extreemly crispy, it looked like it was 20 ohms but since it still does not work, I was hoping you could tell me the value of RK41 and I will try again thanks so much for your help allan apassey@amx.com
  • 106 Answers
It is probably RK42 and the value is 3.9 ohms at 1 watt
Posted on Dec 17, 2008
Hitachi 53fdx20b has yellow line on top and bottom an well as blue, all color if off. What is the problem and how much would it cost to get fixed or can I fix it myself?
It sounds like a convergence problem and is typical for many projection sets.
Parts cost would be under 25 dollars.
The repair consists of getting at and replacing two convergence chips and being able to solder is also involved as they have 18 pins each chip.
Let me know your skill level and I would be happy to help.
Oct 22, 2011 | Hitachi 53FDX20B 53" Rear Projection...
53fdx20b
You can check this link for that convergence that your looking http://www.partstore.com/Search/Model/Hitachi+Ltd/Hitachi.aspx
after you replace thet convergence correctly its should be working fine already..
Good luck.........
Aug 10, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Screen is shrinking and colors are out of alignment
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 14, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX20B - now no pic or sound
The Convergence chips it dead again,might even burn somethings else in ur tv now?Never replaced anythings more or less tolerances in electronics or machanicals equipments only same parts same tolerances.
Nov 09, 2009 | Hitachi 53FDX20B 53" Rear Projection...
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 53FDX20B Rear won't turn on and LED's Flashing
I believe they are the voltage supplies for the TWO convergence IC's that this set uses(either STK-392-110 OR STK 392-150---THEY are interchangeable--but the 150 is a better device)
The easiest way to prove if this is your problem is to locate the two chips (black--2 1/2 inch wide X 1 1/2 inch tall with the STK number printed on them IN WHITE)
If someone unsolders all 18 pins on each chip--see if the set will turn on with them out of the circuit (you do not have to remove them--just unsolder both---If the set comes on the convergence will be very bad but you will know one of the chips is bad.
Also if you look at all the resistors around them (most will have location number RK46 etc) see if any of them are discolored or burnt. You find a burnt resistor and it is a sure bet onE of the chips is bad.
BOTH CHIPS NEED TO BE REPLACED!
A pretty easy repair if you have good soldering skills and I can tell you what you will need to do the repair.
If replacement of the chips fixes the set it just needs to be adjusted with the Hitachi remote and should not have this problem again for 5-8 years.
IF YOU HAVE QUESTIONS, do not hesitate to ask me---I am here to help people.
SD TECH
Oct 09, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Color convergence "whacked out"/blue shadow to right side
Your TV most likely has a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
HATACHI 53FDX20B ERROR CODES
I wish I could help you but when I took my convergence board out rk41 wasnt even used and in the service manual i couldn't find anything about it.
Dec 17, 2008 | Televison & Video
When i turn on tv the screen is turning green
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 11, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX20B
If you have a color (red, green or blue) that is bowed inward from any side, then one of your convergence IC's has cracked loose or burned out. There is no way to fix that manually - the IC and possibly a resistor must be resoldered or replaced, and that should be handled by someone experienced in repairing and realigning convergence circuits.
May 06, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
