Question about Acer TravelMate 2300 Notebook
Acer 3100 screen is black
Acer 3100 screen is balck. Sometimes I can make a ghost of an image. Tried replacing the inverter board. No luck. Any ideas would be appreciated.
  • 3 Answers
If it is a new laptop then, there is the recovery image on your harddisk and it is hidden one. when you buy it normally, you can menu it tells you how to recovery from your harddisk. if you give more detials then i may can help you
Posted on Dec 24, 2008
I have a Toshiba Model # 52LX177 Serial # AM373005009 i am getting horizontal lines with a ghost image sometimes on half the screen, sometimes the whole screen, can you help with this problem please?
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 17, 2016 | Toshiba Televison & Video
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
I have a vizio vx37L that powered on for about 5 10 min then went to a black screen but I could still hear sound. When I unhook the Direct tv it has balck screen still and no sound screen flicks when you...
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is a long shape board.
Apr 21, 2010 | Vizio VX37L Television
I had some water on my screen and the screen is
dear sir my acer desktop pc sound not working sound properties open full option hide
rajan dubai
Mar 20, 2010 | Acer Aspire 5050-5410 Notebook
Acer Travelmate 4p20 Display problem
Try to reset LCD video connector, if you have already changed and tried inverter, then check lamp.
Best of luck.
Regards;
Hassan
Sep 03, 2009 | Acer TravelMate 4220AWLMi Notebook
Acer aspire 3100 screen is black but it works fine through vga.
at the bottom of the laptop screen behind the plastic is a inverter that can fail look one up on ebay ...
20 bucks to fix
New LCD inverter Acer Aspire 2000 3100 5100 5110 5720
Sep 03, 2009 | Acer Aspire 3100-1405 Notebook
Acer aspire 3690, screen all black. haven't dropped
you have a video card dieying call acer and get thier trouble shooting tools to help locate the problem.
Jun 27, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3100 series. Display screen getting dark
This is such a user error. I had the same problem on my 3100-1718. It was as simple as holding down the Fn key and using the left and right arrow keys to change the brightness... I am a goofball for ever letting this stay dark for a month !
Jun 23, 2008 | Acer Aspire 3100-1405 Notebook
Acer aspire 5315
Since the Acer Aspire 5315 works except that the display is dark, then it would be safe to assume that it is only the LCD display part that is the issue. Often LCD display (of laptops) are working but only that you can not see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Acer Aspire 5315.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Acer Aspire 3100-1405 Notebook
Screen goes to black with a ghosting of the last moving image.
This is bad real bad, when this happens it means a board known as the DMD board is failing and must be replaced, the board can run about $650.00 to get it and have it instaled
Feb 07, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Computers & Internet Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
