Oven ignites but fails to stay alight once knob released
  • 69 Answers
The pilot flame sensor is bad. you may be able to clean it with a piece of sand paper, more than likely you will have to have it replaced
Posted on Dec 22, 2008
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Oven will not stay on
try turning the gas up slightly and holding the knob down a few seconds longer after it is alight.
Feb 09, 2013 | Bertazzoni Gas Range
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
Why will my oven not stay alight when the knob is released
these have a sensor that detects the flame of the oven when you relese the button if it sences no heat it stops the gas.
Feb 07, 2010 | New World Spirit 110 (Gas) Kitchen Range
I've been ask to put some meat in the oven but dont know how to switch the oven on, I can turn the knob and smear the gas and i can locate the switch underneath as well but not sure how to? I have tried to...
Turn on the gas knob. Light a match and hold it above the burner at the back. Press the switch inside the oven at the front of the base and hold it in. The burner should light and after about five seconds you can release the bottom switch and the oven should stay alight.
Sep 05, 2009 | 2002 Honda NX4 Falcon
Oven wont stay alight on new world 110G
Hi - I had this problem too. I assume you are referring to the automatic oven, not the manual one. There is a small 'Licon' switch behind the control knob, which provides electrical power to the main gas valve in the oven. It is activated when the knob is turned on and is also connected to the timer clock, so that power is only provided when the timer reaches the cooking start time, or the timer is not being used. I had this replaced by an engineer from New World (at great expense!). Changing it seemed to be fairly straightforward - the engineer removed the two outermost knobs and unscrewed and removed the facia. The switch is behind the main oven knob - but where you might get one from, I don't know. And don't forget to switch off the power before you try to access the switch, as it is likely to be live.
Good luck
Keith E
Nov 27, 2008 | New World Spirit 110 (Gas) Kitchen Range
Gas ove will not stay lighting
Hi there you need to change the ffd on your oven FFd stands for flame faliure device. its like an temperature controlled switch. it is located in the oven and this device is what lets the gas go through once it has reached a certain temp. It must only be done by a corgi qualified engineer and to be honest your loooking at about 100 pounds.
Oct 08, 2006 | Baumatic B604SS Stainless Steel Gas Single...
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
