Question about Syntax SV266AD Motherboard
Syntax motherboar error beep code
Hi, I've tried to upgrade my machine from an athlon to a Sempron. At re-start, the hd cd and dvd lights went on, as normal, but no screen on the monitor and a beep of one sec followed by a 1 sec of pause, in countinuous sequence. Can anybody provide the error code of this beep? There is not in the Manual and I couldn't find it on the Internet. Thanks in advance Liviu
  • 1 more comment
  • liviu grecu Mar 26, 2007
    Thank you, Sandrew,
    Another detaail that I've forgott to mention:after trying the Sempron cpu and getting the error beep, I've switched back to the original cpu and I've got THE SAME 1 SECOND BEEP!
    And I reset the bios a couple of times ! with both cpus !No result, the same beep.
    That's why I was asking for the beep code.
    Liviu
    Thank you Tomj23!
    Tomorrow I will have this info;right now I'm at work and my machine is at home.
    Many thanks, Liviu
  • liviu grecu Mar 27, 2007
    Good day,
    Unfortunately I cannot find any information on the mb manual regarding the BIOS type.
    The only new information I can provide is regarding the beep parameters; is beeping 2 sec and between two beeps there are 5 sec.
    Maybe somebody can figure out something... what means this.
    Thanks, Liviu
  • 624 Answers
I can't find a manual or any info on your motherboard. If you can tell me who makes your BIOS I can probably get you the error code.
Posted on Mar 26, 2007
    President:
  • 2,961 Answers
You may need to reset the cmos on jbat1 terminal with the jumper across pins 2-3 then back to pins 1-2, then boot up and reset time,date and hdd, press f10 to save and exit. this is all assuming your board supports the sempron processor as well as the athlon
How do I access the BIOS setting on this SYNTAX motherboar, not sure of the menu BUT when the system is comming up it does not state what to press to start BIOS sert up.... I tried F2,, ESC, F10, F8 and...
Try DEL.
Try F1.
With the computer turned-off, hold-down the SPACE BAR.
Turn the computer on, until you get "keyboard error, press <blah> to enter BIOS-setup". Press the <blah> key.
Jul 18, 2010 | Syntax S746FX Motherboard
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
CPU Upgrade
Hi there.
Here is a list of processors that board will support >>>>>
http://www.cpu-upgrade.com/mb-ASUS/M2A-VM.html
Good luck and thanks for choosing FixYa!!
May 27, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
Syntax SV266AD Motherboard Logo
111 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Mark Gough
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
