Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Rear Projection TV Sony KPFS 53 M31 :Red screen, 6 times blinking
Hi benmur,
melnavz send me to you for more details, I dont't reallly know where to look.
The problem: Only a red screen at start, then turn off after few second (because the red is getting too bright). The stnad bye led blinks 6 times repeatedly.
I did resold around the mother and the board on the neck of the tube and solde a few point, but did nothing really then I try to shake it (looking for bad contact, nothing again...
I found between the blue and green tube a plastic box with 6 poties, 3 are for the power of each light bulb and the other three for the definition of the picture.
Playing with those tree first I was able to get a reasonable good picture but with a light red shadow. So the red bulb is not overpowering and we have a resonable picture.
But he problem is not solve .
Before finding this "by pass" solution I saw the stand bye led 6 times blinking.
Diagnosis: Low B OCP/OVP(Overcurrent/aver Voltage).Possible causes :5+line is overloaded.(A,B boards), +5 line is shorted.
The sony is a KPFS 53 M31, and I'm not sure that I found the right diagnosis, Can You Confirm if this diagnosis for this TV is right?
Should I buy the schematic for this TV and check what?
Thanks for you help..
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
For any TV model with a CRT or 3 tubes and your description of "red is getting too bright" indicates that the controller transistor or power pack IC for that gun/CRT/tube has shorted. Another possible indicator would be fine diagonal white lines and an overly high contrast.
Often this controller transistor or power pack IC would be heatsinked and located at a squarish PCB (printed circuit board) right at the very small end of the CRT/tube. Corrective action would require replacement.
If the "plastic box with 6 poties" you described would look like the image below, then that would be the Focus/Screen Adjustment for the three tubes.
Rear Projection TV Sony KPFS 53 M31 :Red screen, 6 - 3aff70f.jpg
Unfortunately I do not have a schematic or a service manual hence I could not be more specific. Should you be interested, a service manual is available here.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 17, 2008
10 blinks Sony rear projection
If your model is a KP57WS520 and the light blinks 10 times thats a fairly common issue and there is a repair kit for that error at the following link it bottom of the page
Apr 03, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Light blink 6 times
Your mainboard is gone bad, happened to my tv and they had to replace it.
Oct 09, 2012 | Sony KP-53HS30 53" Rear Projection...
A 53 inch sony tv
blink red light and blank screen every two mintue
Mar 18, 2012 | Sony KP-53HS30 53" Rear Projection...
try this....may have to send board to them for repair.....good success, meder's tv service
Sep 22, 2011 | Sony KP-53S35 53" Rear Projection...
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
TV goes on and off while the red light blinks
Your tv is going into "protection" mode. It has a fault that should only be repaired by a qualified person.
Sep 12, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
TV cannot be turned on
Please count the blinks. It should be a repeating count with a pause. This will indicate the problem circuit and allow us to give you details.
Jul 03, 2008 | Sony KP-53S65 53" Rear Projection...
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Will not turn on.
3 blinks- B+ detected over 150V...135V normal. This may not be true but IC5002 thinks it is. OCP and OVP output from upc393 IC5002, also check R5012 0.22ohm 2W
7 blinks- horz deflect stopped Q8035, Q8038 Hout
6 blinks- 5v line missing or shorted
Nov 05, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
293 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
