Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
SimpleTech 320GB Not Found by PC
I have a SimpleTech 320GB and it is the 2nd external hdd that my computer cant find. It has power cause i can feel it spinning and i connect the USB directly to my PC. Ive had it for a year with no success.
  • Anonymous Dec 23, 2008
    I'm having the same problem, it use to read it fine and now that I had it up to 200 G full it stopped reading it. I connect it and unplug it and nothing happends and I can feel the external drive is on because it's spinning but, my PC doesn't bring it up.
  • nchri170 Jan 15, 2009
    i have owned my simpledrive for about a year and a half. it has worked GREAT. up until Dec 18. then computers can't read it. the drive works fine it spins and all but does not show up on the computer. (every once in a while it will come up as a connected device but there is no way to access it.
  • 6 Answers
Very simple solution. Your external storage cabinet for the drive is junk. I opened mine up and its just fitting loosely in it. You will void your warranty if you do - but who cares, the cost to send it in for an RMA is equal to the cost for a 2.5" SATA enclosure. When you open it up, the SATA and Power connector is not all the way in - push it in and then tape it so it holds together. Plug it in and you should be fine. Fixed two of them that way.
Posted on Aug 13, 2009
Can't find simpletech on my computer - it was there, but it could not let me open it and would not shut off with the eject button to remove. Now my computer doesn't recognize it at all
You can try going in the add / remove and uninstalling the program, then go into devices and remove from there as well. Also go to the folder it is still listed in and find the uninstall there. Delete all those to your recycle bin. Reboot twice! Then on the 2nd reboot, plug the external in and make sure it has power and is turned on. See if it reappears again.
On another site, this next bit is what someone else tried (the last one), see if that works for you.
Storage forum Simpledrive 1TB External HDD Problem
Mar 25, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a SimpleTech Pininfarina 320GB External HDD, however when I have it all hooked up and powered on, the computer does not acknowledge it. HELP?!
they are quite a lot of different formats that hard drives can be run in. Fat 32, NTFS has several formatsof its own. Then there are the Linux and UNIX and Apple formats. By rights many are supposed to be compatible but the some reason they don't always work together.Have you tried running the new hardware installation wizard?I will have a look and see if I can find any information on this problem as I find it to be quite common.Hope this helpsregards
Feb 20, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a Hitachi 320GB 5400RPM External HDD SATA 3.0Gb/s EVGA November '09 P/N: 0a70423 MLC: DA2831 S/N: Q6DM56YM (That's exactly what it says on the HDD.) When connected to my 32bit Vista...
try to use other usb cable or try to plug it at the back of your computer.. if it still goes red, check the hdd inside the external hdd case if it connected or inserted properly..
May 19, 2017 | SimpleTech SimpleDrive Pininfarina 320GB...
Changed internal harddrive and now, computer cannot recognize the simpletech pininfarina external hard drive
If you loaded a driver for the Ext HDD with the old HDD, simply reload it or download off the net.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
USB not recognized
Sometimes it helps to reinstall the drivers for the USB hub/controller in the Device Manager.
For other ideas, have a look at these external HDD troublshooting tips.
Hope it helps.
Jules
Jun 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer does not recognize simpletech
Assuming Windows, try the Device Manager and see if the (old) disk is listed there in the disk drives section.
If so, right-click it and select Uninstall. (do this while the new driver is disconnected)
That should force Windows to recognize and reinstall the new drive when you plug it again.
For other causes check out the external hard disk problems.
Apr 20, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
When my simpletech 320GB External Hard Drive starts up, it starting clicking, and won't be recognized by my computer.
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Apr 05, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
174 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
