Question about Hitachi 42HDM12 42 in. Plasma Television
Buzzing sound and lines, no picture or sound
New plasma tv only 5 months old. When turning it on, it makes a buzzing sound a has vertical lines going across the screen. Doesn't recognize Direct TV box in input 1 or DVD player in input 2. All is plugged in properly. What could have happened all of a sudden??
    Genius:
  • 1,074 Answers
First of all check your connecting wires see if they are not broken inside.or try some new wires.if that does not solve your problem then you have to start looking at the tv as defective,therefore,it ca be either of these problems 1 defective tuner associated with vertical problem. 2 faulty IF-AGC section solution ajdust IF-AGC verify active components leaking,open,or shorted IF transistor or IC REPLACE either.one more thing give it some slight tap on the case if it resume operation you have lose solder then the circuit needs to resolder.if it remains the same considering the above take it to a tech.good luck.
Posted on Mar 26, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
No picture.... makes a buzzing / small bell sound on and off...it has sound but after a minute it turns itself off.
This is a projection tv correct?Yes?The old projection lamp has not been replaced like 1 1/2 or 2 years?Tv in used daily like 4 or 5 hours everydays?Yes?Tv make buzzing sound and bell sound on and off.The tv on the frame the word "LAMP" the LED light indication it is flashing or stay on lit?Yes?Then the tv projection lamp life have ended,tv require a new projection lamp.
Aug 10, 2011 | Mitsubishi WD-60735 Projection Television
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
Buzzing sound on Vizio Plasma TV
likely supply failure or shorted pannel driver. u should be able to unplug the pannel boards from the power supply. if the buzzing stops than its the pannel boards otherwise its supply.
Dec 05, 2008 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
My new Razar V3a makes buzzing sound
If the buzzing is coming from the keyboard then it's a known problem/feature. Got the same on mine when the keypad is lit up, so rag Motorola, who said sorry, known feature with that model.
Aug 29, 2007 | Motorola Mobility RAZR V3
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
