Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica minolta 2300w cant change the yellow cartridge.
Konica minolta 2300w can't change the cartrige. the cartridge is supposed to turn and come to a possition where it can changed, but is
not doing so. Also, in the status display, there is a choice of toner replace, but is not highlighted, therefore can't click on it, to chose the
yellow cartridge
  • Konica Minolta Master
  • 19,396 Answers
Fortunately I did not post on this problem.
I hope you solved your problem.
Regards and good luck.
Posted on Jan 10, 2009
  • 6,487 Answers
Try first to power off the printer for 30 minutes and it should be unplug from the power outlet, then after that power the printer back and then check now if you can already replace it...
Posted on Dec 17, 2008
    Genius:
  • 1,142 Answers
Did you refer to the service manual ?
    Sergeant:
    Novelist:
  • 327 Answers
There is button in the printer.u will just have to remove the cartridge on the top first and then another till yellow comes on top.then after removing yellow replace it and insert the other 1 by 1. in same manner.
Hello. I am getting a message that my yellow toner cartridge is empty and the printer (Konica Minolta 2300W)refuses to print out anything, even though I got it into the B/W mode. The complete message...
It won't print anything if one cartridge is empty, even black when the colour is empty. Are you using new or refilled cartridges? The cartridge has a chip on top that counts your number of prints, so it could feel full, but has reached it's end counter. Try another cartridge. That should solve your problem
Aug 06, 2010 | Konica Minolta magicolor 5430 DL Laser...
I just installed 4 new toner cartridges in my magicolor 2300 DL and I still can't print. It is still tellimg me to change the cartridges. Help!
You have to tell the printer that you have replaced the cartridges.
Here are step by step instructions:
http://www.laserquipt.com/support/idx/0/012/article/How-To-change-a-Konica-Minolta-2300W-cartridge.html
Also, check to make sure that you have removed all the tabs and plastic strips from the toner cartridge.
Aug 04, 2009 | Konica Minolta magicolor 2300DL Laser...
Yellow dots on print
the cartridge is damaged please replace it with another one of the same kind
May 27, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Not printing yellow (64% full)
Go to maintenance and purge ur cartridge.Cheeck regularly ur wiper maybe it will cause clog to ur cartridge.
May 20, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Driver
Here is the link to download your driver.
Konica Minolta Magicolor 2300W
Thanks
Mar 12, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Error with Konica Minolta 2300W
Seems like when you changed the toner cartridge, that the cartridge is NOT SEATED PROPERLY when put back in the printer.
Take the cartridge back out and see if the side cover (held in place with one screw) is able to move freely on the cartridge, sometimes it sticks and won't allow the cartridge to run freely in the printer, thus this beeping noise and jamming of cartridge. there is also some small holes (three in total) on the inner side of cartridge (the side that goes in first) sometimes small bits of plastic are still stuck on the holes from manufacturing and you can remove this plastic around the holes with a knife, and give a free path for the cartridge to rotate.
Jan 27, 2009 | Minolta magicolor 2300W Laser Printer
I replaced the toner cartridges in a Konica Minolta magicolor 2300W. When I turn it on, the drum rotates, makes a beeping type noise and then errors, saying that I need to put in the yellow toner...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
