Question about RCA P60920BL 60" Rear Projection Television
Tv wont come on
I have a RCA 60in. rear projection tv. Model # p60920BL and I turned it off one night, went to turn it on the next day and nothing...it sounds like it is coming on but nothing. HELP
  • 1 more comment
  • lashel Jan 29, 2008
    We try to turn on our TV but all it does is make noise. It never actually comes on though.
  • Anonymous May 06, 2008
    I have the same problem with my 60 inch projection screen Model# P60812BL,,we came home one day ,,and we had a rainstorm and when we turned the tv on all it would do is click 3 times through the speakers,,I check the one fuse and thats good..Any sollutuins welcomed thanks..
  • ptalana Jul 16, 2008
    My RCA P60920BL made a loud pop and turned off and will not turn on anymore. A continuous chirping/beeping sound comes from back of tv by the main panel. Fuse checked ok. Help!!!
    Problem Solver:
  • 5 Answers
I have this particular set myself and a similar problem occured.
I replaced Q14101in the power supply and 5amp fuse.
Also replaced Q14101, horizontal output transistor after I tried to isolate a short on the convergence power supply load. Removing the yoke connectors did this, be carful in your troubleshooting. Also the Sanyo STK730-130 IC switching voltage regulator can cause all these problems to start with by failing, it runs off the main power supply. I think I spent less then $50 to repair the thing myself.
Posted on Oct 14, 2007
    Genius:
  • 1,074 Answers
First tap the set to see if it comes on, if it does not then your power supply circuit needs to be resolder take it to a tech to do that for you, if you are not a tech.if it does not then you are having a serious problem that is to say the following could be defective regulator in the power supply microchip in the standby power supply.high voltage protection circuit.flyback transformer,and all associated components for the above.good luck.
Posted on Mar 26, 2007
  • Henry  Thomas
    Henry Thomas Mar 26, 2007
    therefore, considering the above you will have to take your set to a tech for repais.
Tv turns off as soon as i turn it on then back on with no picture
Look to see if for a tiny fraction of second the power light tries to come on----also from memory I do not know every set---is there a label on the rear with a "chassis" number like PTK169 etc?
Jun 07, 2012 | RCA P60920BL 60" Rear Projection...
RCA rear projection 60in powers off
you need a new light bulb. buy one on ebay for cheap and replace and it will work just as if the tv is new
Feb 10, 2009 | RCA P60920BL 60" Rear Projection...
Tv will not start up
does the front led flash. if it doesnt then you may have a primary power problem.. the fuse may have blowed,., this ussally means other componets have shorted IF the led flashes then you have a processor shutdown
Dec 31, 2008 | RCA D52W19 52" Rear Projection Television
Front panel
Either replace front panel board or all contact switches on that board the one with vol- vol+ ch- ch+ power, menu.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 50in Rear projection TV Turns on and off every 30 seconds-New
if u have only had it a month it should be under warranty get them to repair it
Sep 21, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Tv willnot turn on
Mine just did the same thing on the same day, same tv. we bought ours from Walmart exactly one year ago and after spending time on internet, i have found that alot of us with the same tv have had same problem with no avail from RCA company or walmart. i can't get help from anyone and am ready to scream. Good luck. Others have told me that they have had repair man out and said that it was a malfunction is some type board that he has seen over and over in this tv and he advised to just buy another tv because it was too costly and the problems were going to keep coming with this specific model
Apr 06, 2008 | RCA P52812BL 52" Rear Projection...
RCA Model P52150CP
Replace splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108
Dec 12, 2007 | RCA P52926 52" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
143 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
