Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
I was having problems with my zune so i decided to click on "forget this device"now i want it back and i have no idea what to do.now i restored my zune and i cant get my computer to know my device to get further.my zune says "on you pc open zune software and restore the zune device firmware."i would like to but my pc is not remembering my device.please help
  • 124 Answers
Go to zune website and redownload the zune software then try to reconnect it if this dosent work go to my computer and look for zune and try to restore from there
Posted on Jan 06, 2009
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Can't put music on zune!
1. Sync the Zune with its "home" computer. Each Zune has a specific "home" computer that it automatically syncs with. Use your Zune-specific USB cord to connect your device to this computer, and then sync your device as you normally would. This will solve most software hiccups and will generally get your Zune out of a "frozen" state.
2. Perform a soft reset. If syncing your device doesn't work, you can reset your software by holding the "Back" and "Up" buttons on the central control pad. Your screen will flicker, and then the Zune logo will appear with a status bar. Within a few moments, your software should be returned to normal.
3. Perform a system restore. However, doing this will erase all of your music, videos and photos, so only do this if you have exhausted both of the other troubleshooting steps. You can restore your Zune by connecting it to your computer, selecting it from the "Devices" list, and then pressing the "Restore" button. The process may take a few minutes, depending on how much content you had on your device. Once the restore has finished, your Zune will be completely blank.
Sep 30, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Windows 7 (64 bit) build 7000 and zune problem
i had the same problem at first with my 3rd generation zune. first you have to open up the zune software folder then right click the short cut and click run as administrator then it will detect the device and everything will work. good luck
Mar 19, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune freezes and says contact support
in order to fix this . you have to restart the device. to restart the device you press and hold back while also pressing and holding the top part of the zune pad until screen goes blank and zune logo appears this should work. if contact support comes back up try restoreing the device.
for more info on how to restore the zune go to zune.net/support and press technical issues and a list with how to fix any problems will appear
Jan 09, 2009 | Microsoft Zune JS8-00001 Digital Media...
Broken zune
i get the same exact problem what i do is restart my computer and plug my zune into a diffrent usb port(i have 4...2 in the front and 2 in the back) and my back ones work fine try that and let me know if it works
good luck
~Temp
Aug 28, 2008 | Microsoft Zune JS8-00001 Digital Media...
FROZEN ZUNE 80gig
Message on your Zune device: "Screen 5 Contact support" View products that this article applies to. function loadTOCNode(){} Article ID : 926993 Last Review : June 20, 2008 Revision : 5.0 SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following message on your Zune device: 5
Contact supportuparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); This issue occurs when your Zune device cannot recover from an error.uparrow.gifBack to the top
THINGS TO TRY loadTOCNode(1, 'whattotry');There are two easy things to try that might help with your problem before you contact Zune Support: 1. Try restarting the Zune device. To do this, set the hold switch to the unlocked position, and then press and hold the Backzune_button_back.gif button as you press on the top of the Zune pad. When the Zune device begins to restart, you can release the buttons. 2. If you receive the same error message when you restart the device, try restoring the Zune device software. For more information about how to restore the Zune device software, click the following article number to view the article in the Microsoft Knowledge Base: 927001 (http://support.microsoft.com/kb/927001/) How to restore the Zune device software If restoring the device was unsuccessful, sign in at the following Web page and determine whether your device is still in warranty: http://service.zune.net (http://service.zune.net)If your device is in warranty, it may qualify for service. You can submit a request for service at this Web site.
May 30, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune
try{MS_AddEvent(window, 'load', function() {try{CreateAC({id:'query', lcid:'1033', initialValue:'', acURL:'http://autocomplete.support.microsoft.com', statsObj:StatsDotNet, startChar:'4'});}catch(e){}});}catch(e){}
var curspid = ''; InitSrch(); InitAC(); Message on your Zune device: "Screen 5 Contact support" View products that this article applies to. function loadTOCNode(){} Article ID : 926993 Last Review : June 20, 2008 Revision : 5.0 SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following message on your Zune device: 5
Apr 05, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Can't get my Zune software to forget my device
I had to replace a Zune that was dropped in water. I didn't bother trying to get the Zune program to forget the other Zune. I just attached it and started syncing my stuff. Did you try that? BTW I named the new one the same thing as the old one with no problem.
Jan 12, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30GB black
if it says "contact support" restoring it will not work anymore. listen to the zune's hard drive. if it spins but makes a repeittive noise, the HDD is broken. if it doesn't spin at all either the hard drive of the motherboard may be broken. on the 80gb zune it's usually the logic board or the hard drive cable that causes this. there is a zune repair tutorial online gives you an idea on how to do the replacement yourself. parts are on ebay.
Dec 17, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
140 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
lugnuts1
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
