Hp photosmart c4200
Computer says the device is not attached. I have tried to re-install and it says it is not recognized. I have switched USB ports and tried another cable with the same results. Any thoughts?
  • wego25 Dec 18, 2008
    Thanks for the help. It took care of the problem. It probably seemed like a little thing to you but I am no computer wiz so when things happen out of the norm it can be very frustrating.
    Master:
  • 638 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Dec 17, 2008
How to install hp photosmart 2573 all-in-one in my computer
connect all power and data leads to your computer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
http://download.cnet.com/hp-photosmart-2600/3000-2116_4-69704.html
http://download.cnet.com/hp-photosmart-2570/3000-18489_4-81851.html
Aug 06, 2012 | Generic 2 Pc To 1 Usb 2.0 Device Ab Switch...
Computer won't recognize USB port HP Photosmart 7960
when you plug in the printer and turn it on do you get the sound that a USB device as been added
NO :
try a different cable
YES :
it might be worth trying new drivers only ad downloading the latest version direct from the manufacturer
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-18223-2&cc=uk&dlc=en&lc=en&os=228&product=305383&sw_lang=
Hope this helps
Dec 14, 2011 | HP PhotoSmart 7960 InkJet Printer
New printer not recognized?
Here two causes are possible first your driver that you installed is not insralled properly so turn off your computer, reboot, delete HP Photosmart C4480... driver from the printer list icon and install again properly.(if you will not get the right solution of your problem then try the next step)
Second your U.S.B. cable maybe faulty so change your U.S.B. cable.(if you will not get the right solution of your problem then try the next step)
Third your U.S.B. port of computer is faulty so cahnge the port(many computer have more then one U.S.B. port if you have so try one(if you will not get the right solution of your problem then try the next step)
and
after this all you try your installation on other machine.
I hope you will get your problem solution.
thanks
TTYAGI
Apr 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Having trouble installing HP Photosmart All in One Printer. Model C5280. Near the end of installation it ask's for printer to be connected via USB cable. Msg comes up on screen 'USB Device not recognized'...
Dear Sir:
It seems that the printer has gone bad because when you get this message 'USB Device not recognized' it means that the usb device connected to the computer is defective however I would suggest you to connect this device to another computer and if you are getting the same error with the other computer.
Please contact hp support they should be able to help you with this.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Jul 19, 2008 | HP Computers & Internet
Hp laser jet 1018 problem
try to connect the usb of your printer at the back usb ports of your CPU. and try to scan your device.
or
Do as follows inst.
Unplug your printer usb on your system. then attach it back to your computer then power on your printer.
Do right click my computer>properties> in system properties select hardware> then, click the Device Manager> tab, then select your device on PORTS. then click the scan for hardware changes> to scan your device. this icon can be found above or click Action menu and select >scan for hardware changes.
then restart PC. Hope you can do it. And it will help you.
thanks.
Jun 04, 2008 | HP LaserJet 1018 Printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP photosmart C3180 not recognized?
Looks like a bad usb cable..did you try it with another USb cable?
Nov 25, 2007 | HP Photosmart C3180 All-In-One InkJet...
127 people viewed this question
jasbo
jasbo
