Pc graphics problem cant slect high color
My windows me that i have just built is running on 16 colors which is very low color so i have changed my graphics card to a turbo 3d enhancer but when i go to (right click - properties - settings - color ) when i select high color 16 bit it asks me to restart which it should not so then i restart my pc and it dose not work and after the settings have supposed to be changed they are not does any one know the answer to this.
  • eric grapner
    eric grapner May 11, 2010
    The proper procedure for installing a new card is:
    - remove old card drivers
    - shut off pc and replace the card
    - boot pc and install new drivers
    You haven't clarified you've installed new drivers and that may simply resolve the problem at this point. 95, 98, and ME will hang on to your old drivers so you can reboot into Safe Mode, access the "Control Panel" and then "Hardware Manager" and open the video display category and right-click and remove all your old video drivers. Then reboot to your new drivers.
  • JDTec
    JDTec May 11, 2010
    This means that your video drivers are not installed properly. First find out what video board or on-board video you have. the download and install the correct drivers
  • 115 Answers
First uninstall all the graphics drivers you have installed. Restart the computer and install the current graphics driver if required.
Go to display properties --- settings---- color and select the desired option and click "advanced"
on the next screen under "general" ---- "compatibility" select the 2nd option " apply new display settings without restarting"
Your problem may be solved.
Posted on Dec 17, 2008
Monitor result change 16 colors
One of your applications are changing your color scheme to 16-bit because it isn't compatible with your OS or graphics card. Try reinstalling your drivers, then disabling programs one by one when the problem occurs. For example, games that used to run on windows XP or older tended to change the color scheme and resize the monitor to 480p.
May 19, 2014 | Nvidia Computers & Internet
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Wddd COMPATIBLE drivers
You will not have the Transparency option if you have a Basic and High Contrast Theme instead of a Aero Theme.
Aero Requirements to be Enabled in Windows 7:
NOTE: If Aero is not enabled, then Transparency will not work even when enabled.
Feb 05, 2010 | HP Pavilion dv2000t Notebook
Changing my colour on desktop
You'll have to run the game in compatibility mode, with the color depth set to 256 colors.
You do this by right clicking on the executable of your game. click on Properties. Compatibility tab. Click the check to run compatibilty w/ Window 98, and set the color depth to 256 Color. That should work! Happy gaming.
May 30, 2009 | Computers & Internet
WINDOWS 98 EXTEND MY WINDOWS DESKTOP
You need to download and install the necessary video drivers for your computer's graphics card chipset.
If your computer has a PCI or AGP graphics card, you can power off your computer and then unplug it, open the computer case, and then check the graphics card to see either its make and model or simply write down the info about its chipset. The main graphics chip on the card, for example, might say SIS 6326. You would then go to the SIS web site and download the Win98 drivers for this graphics chipset.
If the graphics is built into the motherboard, then you can look on the motherboard for the graphics chipset model, or consult the motherboard manual or search online to see what graphics chipset the motherboard uses. Video drivers for motherboard chipsets can be downloaded either from the motherboard manufacturer's web site or from the chipset manufacturer's web site.
Once you have installed the appropriate video chipset drivers, the installation utility should ask you to reboot the computer. After you have rebooted, right-click on the desktop and then go to the Advanced settings. You should now be able to increase the color depth and screen resolution.
Mar 18, 2009 | HP Easy Refill Kit for (HP) Color Inkjet...
Computer coloring
it's look like your vga driver isn't installed properly. or maybe you installed wrong driver.
Try to install it again.
Mar 01, 2008 | Computers & Internet
Colour pallet
Click on the "Window" tab at the top and scroll down to "color pallettes".....then just slect whichever color pallete you want to work with.
Oct 26, 2007 | Corel AE CorelDRAW Graphics Suite 12 for...
Turbocad V10.2 will not work with Windows Vista basic
well, turbocad deluxe 10 is NOT compatible with vista. Here is the compatibility list : Windows 98/Me/NT4/2000/XP Pentium-class PC 64 MB RAM (128 MB recommended) 55-212+ MB hard-disk space 64 MB of swap space Super VGA (1024 x 768) display High Color (16 bit) graphics card 4x CD-ROM drive with 32 bit drivers
Jul 16, 2007 | IMSI TurboCAD Deluxe 10 for PC
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
