Solution #1
posted on Jan 24, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
How can I turn the glare down on my LCD monitor? If someone can suggest a solution I'd like to know. I have a non-reflective monitor.
But the glare is too much from the backlights. Thanks, DB
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 08, 2005
Jimmy NY - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Glare on your computer monitor is more than just an annoyance. It can leave you with eyestrain and a headache. Taking the shine off your screen should be an ergonomic priority.
1. Evaluate your computer setup to determine whether the monitor is optimally positioned. You don't want the screen to be facing a window, nor do you want to be facing a window yourself--a position that can cause eyestrain from too much light contrast. The ideal screen-to-window angle is 90 degrees.
2. Reduce the amount of bright sunlight in your workplace. Shades, blinds and draperies all help block sunlight. Even switching to a flat rather than glossy wall paint can help.
3. If you have a bright light source directly above your screen--the worst possible place and typical of many offices--try turning it off and placing a small desk lamp to one side of your computer instead.
4. If you can't avoid overhead light, you can construct an anti-glare hood for your monitor by taping together several sheets of black cardboard and using them to frame your monitor screen.
5. If you can't avoid bright light from a window (or if you think a hood looks too goofy), purchase an anti-glare screen to place over your monitor. Generally, the best ones are polarized or have a purplish optical coating.
Suggest a new solution for this problem
Post a New problem for Smart Modular SV3170A
Email this problem
Email this problem
This Problem Also Relates To:
HP 2025 (Carbon, Silver) 20.1 in. Flat Panel LCD Monitor
Philips 190B6CB/27 19IN LCD BLK
Philips 107E61 (White) 17" CRT Monitor
Philips 190B7CB (Black) LCD Monitor
Philips 170C4FS (Silver) 17" LCD Monitor
Philips 230W5VS (Silver) 23" LCD Monitor
Philips 170B4MG 17" LCD Monitor
Can you Help with these Monitors problems?
Smart Modular SV3170A (Black)
sleep mode onthe moniter
I hooked up a different to my... Answer This...
Getting the monitor to stay on...
when I try to close the laptop... Answer This...
Repair Service
Find Monitor Repairman Near You:
