SOMETHING IS WRONG WITH MY RECEIVER. WHEN I TURN IT ON, AFTER TWO OR THREE SECONDS APPEAR "PROTECTOR" IN THE DISPLAY AND I CANNOT DO ANYTHING . WHAT COULD I DO TO DISABLE IT
Comments:
Dec 17, 2008
- thank you for your help RENOSEAN, but it is still flashing the word "protector" in the display.
You cannot disable it. It is meant to protect the unit from producing more power than it is designed to. When you turn it on, turn the volume all the way down. Beyond that consult the back of your manual for trouble shooting and service information.
Comments:
Dec 17, 2008
- Well the only other thing that it can be is trying to reset the memory. This can be done by unplugging it for 8-24hours followed by pressing all the buttons on the front. If that does not work then I am sorry to say but it is too late for the stereo, the capacitors are fried.
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to...
(More)
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to factory specs per the Sony manual instructions... to no avail. I do not have anything connected to the surround inputs. Although I have the Sat/TV, DVD and Video 1 inputs connected. Prior to moving, I discovered the right rear channel not functioning (I noticed the right rear speaker problem after a Direct TV installation tech switched out my Direct TVR. I assumed that it was a loose wire) now it seems neither of the two rear channels are working.I disconnected and reconnected the speaker wires. I ran the onboard "tone" check and the three front speakers function and supply the 'white noise' indication. The rears are silent when the display indicated that they were being tested. Are the rear speakers fuse protected? Anyone with an idea of what might be going on??
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from...
(More)
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from relay 2)Display intermitantly works
Plug it in and demo starts, never stops and power switch will not stop it Switch opens &...
(More)
Plug it in and demo starts, never stops and power switch will not stop it Switch opens & closes normally.
