Question about Technics SL-1200MK2 Turntable
Connect turntables(technics SL1210MK5) to a mixer?
What kind of cables do i need to connect booth of them to the mixer?
  • 515 Answers
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
Hi there, i just bought 2 Technics mkii
well" for a start, they need to go into a phono socket, this amplifies them.
i take it you bought 2 decks with the intentions of mixing, so you gonna need a mixer.
MIXER & DECKS SET UP:
1.decks into phono channels 1&2
2. black GROUND wires, go to GND screw on back of mixer
3. RCA master / booth Outputs on mixer to AUX / LINE-IN on amp.(not phono)
Oct 09, 2013 | Technics SL-1210 Turntable
How to record from decks to mac air?
get a USB interface sound card, then come out of the mixers REC OUT or BOOTH, in to the USB's LINE IN or MIC.
Then you'll need some recording software installed.
Mar 03, 2013 | Technics SL-1210 Turntable
Can i connect 2 amps on djm 3000? If yes how?
I currently have 3 amps connected to one mixer. All you need is to check where your amp is currently plugged into the mixer. now get yourself 2x RCA two way splitters at your local music shop (ie. One male to 2 female)split the channels from your mixer input, and an extra amp can be plugged into the spare plugs
Apr 14, 2010 | Pioneer Djm-909 DJ Performance Mixer with...
Hello, I am trying to plug my Mixer into my amp but only one speaker has sound..I am using a Rane ttm57sl mixer with technics turntables & cambridge audio azur 640a amp...I've gone from the Aux out on...
Why don't you try using the main outputs (the 2 XLR connectors). With 2 cables connect these two (left - right) outputs at your amplifier's aux in. In that case take care that the "output level" of the mixer works like master volume controlfor the signal that the mixer sends to the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 04, 2010 | Cambridge Audio Azur 640A Amplifier
What do i do with the earth cable on my technics to stop the humming?
If you are connecting it directly to a HiFi amplifier, connect the ground lead of the technics to the ground termination on the back of the amplifier.
If you are connecting to a Dj Mixer, connect the Technics ground lead to the ground on the back of the Dj Mixer.
Make sure the ground is connected securely and will not fall off. To check this, after connection give a light pull on the ground cable. If the lead comes away, reterminate (connect).
Nov 09, 2009 | Technics SL-1210 Turntable
Technics SL1500 will not connect to new Sony STR-DH100 receiver
Unfortunately, a turntable runs on a different frequency, and if there is no button at the back of your receiver to change the frequency setting on that channel, it wont give you any sound. the best bet is to go to your music store and purchase a small DJ mixer. connect that to your receiver, and run the turntable through your mixer. the mixer will have the neccesary flip switches and "ground" connections
May 06, 2009 | Audio Players & Recorders
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jan 18, 2009 | Technics SL-1210 Turntable
Instruction manual for ministry of sound mixing decks
What are Ministry of Sound mixing decks? I am familiar with MOS, but was not aware they manufactured mixing decks?
Are you connecting these to a DJ mixer, or a Home Receiver?
If it's going through a home receiver, make sure you have them connected to the PHONO input on your receiver. If your receiver does not have a phono input, and you are connecting to the LINE IN or AUX IN section on the rear, you will not hear much. Most turntables require a pre-amplified signal, and only the PHONO input has this option. So, you will need to purchase a PHONO PRE-AMP, and connect your turntable to it, then connect the PHONO pre-amp to the LINE IN.
If you are connecting to a DJ mixer... same thing. Make sure you have them connected to the PHONO INPUT on the mixer. If you still don't get anything, then there might be something wrong with your mixer.
If you could clarify you exact set up, and the EXACT models, we can help you better.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
No music
Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
1) Tonearm
2) RCA Cables
3) Cartridge
There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.DJPROLAB.com
Jul 16, 2008 | Audio Players & Recorders
Very low volume!
If you're used to playing your vinyl through a hi-fi turntable (and not DJ turntables) then you're probably used to your turntable having a built-in amplifier. DJ decks don't have these and if you plug into 'line' it will come out very quiet. Try plugging into 'phono' if you have it, if not you'll need some extra amplification somewhere between the deck and the speakers (a mixer usually takes care of some of this before it goes into the main amp of the system). Hope this helps. Ad
Aug 06, 2007 | Sony PS-LX350H Turntable
Technics SL-1200MK2 Turntable Logo
954 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
