SOURCE: I have a Fujitsu Siemen Amilo pro V2035,. I used
Go into control panel/Sounds and audio devices and check the mute button is unchecked
SOURCE: Fujitsu Siemens Amilo M7400 FB21 WLAN Problem
you will have to open up your network connections Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledi click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection hope this helps you
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
SOURCE: sound driver Fujitsu Siemens W26361-w52-x-01 Motherboard w26361-w52-z2-01-36
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html rather doing a driver hunt http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 note: it will find all of your outdated drivers this is a free driver solutions which will automatically search for and find the correct driver it might take some time being free just type in what you want or need be specific you might have to try a few times to get it right IE: motherboard name sound drivers http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program hope it helps
if this driver is not right
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue
updating each driver free then restart once all of the drivers have been updated
also
http://download.cnet.com/2000-20_4.html
