Question about Sony Playstation 3 (PS3) Console
How to get around Feedback?
Just got a PS3. Every once in a while, especially when I put a BlueRay video in, my TV's speakers give out feedback. Calling the otherwise useless support line, I learned that the Coaxial cable from my cable box causes the feedback with the PS3. How can I get around this? Will HDMI cables work? Please don't tell me to unplug my cable. I'll sooner return the system then be forced to be inconvenienced like that.
HDMI cables will fix that. the feedback is because your playing a high res video on a low res tv (im just assuming you dont have a 1080ip TV) i had the same problem for a while until i got a 1080ip. you shouldnt have to unplug the cable.
Posted on Dec 17, 2008
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
Controller giving feedback?
If you are not using a microphone, then you are not the feedback source.
That being said, a blue-tooth headset still qualifies as a microphone, and is capable of generating feedback.
If using blue-tooth, then switch to a standard wired headset to determine if the feedback diminishes.
Regardless of headset type, be sure to have game chatter through the headset only setting as opposed to through the TV speakers, and keep the TV turned down. There will be an obvious lag between TV speaker and headset microphone which can create a feedback loop.
If other gamers can hear your TV when you are talking, then the TV output is too loud and will create feedback opportunities.
If none of the above applies, then the feedback is generated elsewhere.
Hope this helps!
Apr 22, 2012 | Microsoft Xbox 360 Wireless Controller
PS3 will play games but will not play DVD's
the blueray and a thing called a pot on the inside of the casing to the blueray which u can open and trweak a little with a screw driver so that the ps3 starts recognising dvds again any more questions just ask please give positive feedback im trying to sort this problem out personly you with untill its gone so please at least give me positive feedback and i hope we can fix your problem together.thank you
Jun 04, 2011 | Sony Playstation 3 (PS3) Console
DENNON AVR-2016 - can't seem to turn it on - it turns off after a few seconds. Help! maunog@hotmail.com
Check the speaker wires at both ends for possible shorts. One tiny strand of copper is enough to do it, and set off the amp protection circuit.
If there are no problems with the speaker wires, also check your RCA plugs for a loose or shorted connection. (Turn down the receiver volume to about -30dB or lower before the amp clicks on when checking.)
Is the signal distorted before it cuts out? Another possibility is a feedback loop, in which you have a source (especially a TV) that is both receiving and supplying a signal to the receiver without going through a tape-loop circuit like VCR1, etc. For example, if you connect the output from the TV to "TV" and also have a DVD player running through the receiver *to* the TV, you'll get a feedback loop which will overload the receiver and may trigger the protection circuit.
Feb 09, 2010 | Denon Audio Players & Recorders
My ps3 wont load games anymore
Replace the Blueray drive will shore up this issue you can try cleaning the drive wiht a cleaner CD and see if that shores it up if not simply replace the drive and you should be in good shape, thanks and please leave postive feedback ether way.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not loadin jst sayin on the start up page
This could be due to a faulty blueray drive most of these give out, Specially the first generations thus it will cost $150 to put a new one in.
Other reasons being the drive could be dirty you can purchase a cleaning kit for it and try running that.
But most likely its the drive.
Thanks and please leave a positve feedback and rating for your free answer today.
Oct 14, 2009 | Sony PlayStation 3 40GB System
A slight feedback noise from speakers while playing playstation 3
probably your wires. any time speakers hum something is not connected properly or there is interference from another gadget nearby. Invest in some better wires and your problem should go away
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
It seems I keep getting feedback from my speakers...it was working fine for one day and the next is just started to give feed back....is this a blown speaker problem?
try hooking up a good speaker then if there is no feedback then it was the others, if feedback occurs with the good speaker it would most likly be the receiver or the speaker teriminal, like a stran of wire touchin from the positive to the negetive,
Oct 30, 2008 | Audio Players & Recorders
Speaker feedback
I have the same as yours, my solution I placed the speaker with controls closest to the CPU, just less than 10 inches away and the excess wires "especially the Input line" is rolled up and wrapped it with a foil, "the silver wrapper"... So far I have filtered the noise that interferes with my listening...
I hope it works on your system... Mine is Creative SBS20... What's yours anyway?
Jan 31, 2008 | Audio Players & Recorders
Some kind of feedback
I suspect that what you are referring to as "feedback or "low hum" is actually 60cycles AC hum coming from the mains. Though this is fairly common, it is quite challenging to figure out corrective actions since you have to do trial & error to determine which of your cables/devices combination would start the hum.
In some instances, this could be corrected by inserting the AC plug of the device the other way around to the mains outlet (if the prongs would allow it). Further, a filtered powerstrip instead of the wall outlet would probably also help.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
