Question about HP Pavilion zv6270us (EC365UA) PC Notebook
I want to open my HP Pavilion zv6270us so that I can clean the fans. I think they are dirty and do not work every time the laptop needs them to work. How do I disassemble it?
    President:
  • 1,073 Answers
Here is the manual for you laptop
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&os=228&product=1127348&
There you can see how to open it
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 17, 2008
HP dv6810us laptop fan too noisy? Any solutions?
Here is a simple guide to cleaning your laptop fan if your are comfortable opening the computer.
http://www.rightinfonow.com/laptop-noise
If not it is most likely that the fan is clogged with dirt and dust and just needs cleaning. If blasting it externally with compressed air does not work you or a local tech will need to open the computer and clean it.
Thanks
Dustin
Jan 12, 2011 | HP Pavilion dv6810us Turion Notebook
I have a HP Pavillion 2005. it would shut down
Could be your fan is bust or very dirty try cleaning it and the air vents. NB opening your pc may void warranty.
Mar 30, 2010 | HP Pavilion zv6203cl Notebook
Loud fan noise from hp laptop pavilion dv4.
Try to modify your power plan, i modified the value of process power management and fan noise came down havily. This can be found under advance setting in Power plan.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
Noisey fans
Noisy fans are not dirty fans, they're simply noisy. There is nothing to clean.
Nov 03, 2009 | HP Pavilion zd8000 Notebook
HP ZD8000 Some questions
When it comes to overheating, its because the laptop is in a dirty environment and what happens is the fan from the cpu is sucking up all the dirt and dust so its getting caught up between the cpu fan vent and the heatsink thus less air flow and components getting hotter.
Just make sure your laptop is in a clean environment and has enough room to breathe when running and everything will be fine.
Jun 11, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion DV6500 - The fan makes too much noise!
If at all possible " do not try and clean the fan yourself " you will kill the m/board - take it to an auth Hp serice agent and get a new CPU heatsink assy & fan unit fitted. I work on Hp units all the time and I am always very carefull of the electrostatic conditions. Try and do it yourself and it will prove expensive. If you have warranty log a service call for a replacement heatsink
Glenn
May 09, 2009 | HP Pavilion DV6500T Notebook
Loud fan on hp pavilion laptop dv8000
Your fan is getting old and dirty, and will probably fail at some point. The cheap plastic bushings usually wear out, that is where you hear the noise.
Sometimes a good cleaning with canned air will help you. Usually there are vents on the side and bottom of the laptop you can blow from one hole in short spurts out the other hole.
Some models you can remove a few screws on the bottom and get right to the fan and clean it or replace it if needed. Usually they come with a heat sink for the CPU also, so it is an assembly.
Cleaning is your first step to see if that helps. There are usually big furballs in there!
Apr 12, 2009 | HP Pavilion dv8000t Notebook
Fan noise somewhere under the Enter button
It is not a good idea to turn off your fan. Your fan is crucial to making sure your CPU stays cool enough so that it will not overheat. It sounds as if your fan may be dirty and needs cleaning, but being a new laptop it should still be under warranty. I would call the support line for the manufacturer and let them look at it and they will replace it if needed. If it is under warranty save yourself the headache of trying to fix it yourself unless you are confident and experienced. Good Luck!
Mar 13, 2009 | HP Computers & Internet
Over heating
I would suggest you to check the heatsink and cpu fan,
it could be dirty, if it is dirty, clean it and it should work fine.
To see heatsink and cpu fan, open 4 screw on the back of your laptop.
remove the cover, remove the fan screw (3), remove fan,
remove 4 screw on the cpu heatsink, remove the heatsink.
if your heatsink and fan are clean, it could be something else cause the shut down.
in this case you should send it for repair.
Oct 07, 2008 | Computers & Internet
HP Pavilion zv6270us (EC365UA) PC Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
